ESP32 conneted WIFI to SMARTPHONE ....Mystery !!!
Posted: Mon Jun 20, 2022 9:48 am
by ixbo
Hello
An other mystery I try this program to scan wifi , i'm in the nature connected
to nothing,only my smartphone.
My smartphone (SAMSUNG S9) is configured as acces point to INTERNET.
if sta_if.isconnected():
    print("     IP               MASQ           GATEWAY        DNS       ")
    print(sta_if.ifconfig())
nearby= sta_if.scan()
print("Liste des reseaux WIFI")
for j in nearby:
    print("Nom reseau: ",j[0])
    print("SSID: ",j[1])
    print("Canal: ",j[2])
    print("RSSI (db): ",j[3])
    print("Autorisation: ",j[4])
    print(sta_if.ifconfig())[color=#008000][/color]
This program work without PASSWORD AND
without SSID
>>> %Run -c $EDITOR_CONTENT
IP MASQ GATEWAY DNS
('192.168.43.85', '255.255.255.0', '192.168.43.1', '192.168.43.1')
Nom reseau: b'AndroidAP46E7'
SSID: b'n\xc7\xec;F\xe7'
Canal: 6
RSSI (db): -34
Autorisation: 3
I don't know why
I have an other program witch send data to THINGSPEAK ,working well at home connected to a Box, it seem working well connected to smartphone but nothing is send to the cloud !!!
Maybe there's someone who could explain me ???
Thanks very much
Re: ESP32 conneted WIFI to SMARTPHONE ....Mystery !!!
Posted: Mon Jun 20, 2022 11:25 am
by jimmo
Thanks very much
Sorry I'm not quite sure I understand your question...
Your device is connected, and it's listing scan results. What were you expecting to see?
Posted: Mon Jun 20, 2022 3:08 pm
by ixbo
Hello thanks for your answer.....
I'm not sure but I will explain ...
I have a program named "main.py" loaded in my device This program can connect to my smartphone as box wifi
SSID and PASSWORD are needed ......,
When I power my ESP32 the main program start and WIFI is configured.....But now I create an other program with THONNY witch also use the same wifi connection
I run it with the Run bottom on THONNY .....i remark that PASSWORD and SSID are not needed.....
The reason is that my device is not reseted when running an other program, parameters created by the main program are always present
It's not the same logic what I'm used when programming MICROCHIP ....in ASSEMBLER
Thanks very much......very nice
Best regards
Posted: Tue Jun 21, 2022 12:12 am
by jimmo
The WiFi system on ESP32 runs somewhat independently of MicroPython. Unless you do a full reset, it will stay connected. Thonny is only doing a soft reset (which only restarts the Python VM).
