ESP32_BLE - How to get message
rnemeth
Post by rnemeth » Wed Jun 22, 2022 8:33 pm
could you please help me get the message in main.py? I would like to further use the message I get via ble.
Thank you in advance!
main.py
from machine import Pin, Timer
from esp32_ble import BLE
ble = BLE("ESP32")
print(ble.get_message())
esp32_ble.py
from time import sleep_ms
import ubluetooth
class BLE():
    def __init__(self, name):
        self.name = name
        self.ble = ubluetooth.BLE()
        self.ble.active(True)
        self.led = Pin(2, Pin.OUT)
        self.timer1 = Timer(0)
        self.timer2 = Timer(1)
        self.disconnected()
        self.ble.irq(self.ble_irq)
        self.register()
        self.advertiser()
        self.message = ""
    def connected(self):
        self.timer1.deinit()
        self.timer2.deinit()
    def disconnected(self):
        self.timer1.init(period=1000, mode=Timer.PERIODIC, callback=lambda t: self.led(1))
        sleep_ms(200)
        self.timer2.init(period=1000, mode=Timer.PERIODIC, callback=lambda t: self.led(0))
    def ble_irq(self, event, data):
        #global message
        if event == 1:
            '''Central disconnected'''
            self.connected()
            self.led(1)
        elif event == 2:
            self.advertiser()
            self.disconnected()
        elif event == 3:
            '''New message received'''
            buffer = self.ble.gatts_read(self.rx)
            self.message = buffer.decode('UTF-8').strip()
    def get_message(self):
        return self.message
    def register(self):
        # Nordic UART Service (NUS)
        NUS_UUID = '6E400001-B5A3-F393-E0A9-E50E24DCCA9E'
        RX_UUID = '6E400002-B5A3-F393-E0A9-E50E24DCCA9E'
        TX_UUID = '6E400003-B5A3-F393-E0A9-E50E24DCCA9E'
        BLE_NUS = ubluetooth.UUID(NUS_UUID)
        BLE_RX = (ubluetooth.UUID(RX_UUID), ubluetooth.FLAG_WRITE)
        BLE_TX = (ubluetooth.UUID(TX_UUID), ubluetooth.FLAG_NOTIFY)
        BLE_UART = (BLE_NUS, (BLE_TX, BLE_RX,))
        SERVICES = (BLE_UART, )
        ((self.tx, self.rx,), ) = self.ble.gatts_register_services(SERVICES)
    def send(self, data):
        self.ble.gatts_notify(0, self.tx, data + '\n')
    def advertiser(self):
        name = bytes(self.name, 'UTF-8')
        self.ble.gap_advertise(100, bytearray('\x02\x01\x02') + bytearray((len(name) + 1, 0x09)) + name)
Re: ESP32_BLE - How to get message
Post by jimmo » Fri Jun 24, 2022 12:37 am
This code:
ble = BLE("ESP32")
won't work because it will just run immediately. You need to wait until there is a message before you can call get_message.
I highly recommend taking a look at the aioble library for working with BLE https://github.com/micropython/micropyt ... oth/aioble
In your case it will mean you don't have to write any of the event/irq handling, and you can use `await` to wait for the message to arrive.
