ESP32-CAM with ILI9341
TRMrNo
Post by TRMrNo » Sat Jul 02, 2022 10:13 am
I am trying to display live video on ILI9341 SPI display. JPEG function of the camera is working properly. However I could not get any image when I configure the camera in RGB565 format.
Does anyone make such an implemantation ?
Or do you know a library which can display jpeg image on LCD display, In case I use the camera in JPEG mode ?
Or do you know a library which can convert jpeg to raw RGB565 format ?
camera.init(0, format=camera.RGB565, fb_location=camera.PSRAM)
buf = camera.capture()
>> buf
>> False
spi = SPI(baudrate=40000000, polarity=0, phase=0, sck=Pin(14), mosi=Pin(13), miso=Pin(12))
display = Display(spi, dc=Pin(2), cs=Pin(15), rst=Pin(0))
state = camera.init(0, format=camera.RGB565, fb_location=camera.PSRAM)
#state = camera.init(0, format=camera.JPEG, fb_location=camera.PSRAM)
print("Camera State: ",state)
camera.framesize(camera.FRAME_96X96)
    buf = bytearray(2 * 96 * 96)
    display.block(0,0,96,96,buf)
    print("image")
    display.draw_rectangle(0,0,96,96,255)
Best Regards
tepalia02
Re: ESP32-CAM with ILI9341
Post by tepalia02 » Sat Jul 16, 2022 10:45 am
Since you're getting no response here, I think you can address your problem in this thread: viewtopic.php?f=14&t=1996&start=10
