Sending data to influx db using http
Groovy3286
Post by Groovy3286 » Mon Jul 04, 2022 9:27 am
Hey I have an ESP32 with micropyton firmware, and a locally hosted influx database. I want to send just plain text from the ESP32 to the influx db (have a dht22 sensor hooked up to the ESP32). I am super confused as to how I would go about doing this, looked around and seen POST but not entirely sure how to use that properly.
Re: Sending data to influx db using http
Post by jimmo » Mon Jul 04, 2022 12:23 pm
Yes, you can use HTTP POST requests to send data -- the docs are here: https://docs.influxdata.com/influxdb/v1 ... fluxdb-api
On MicroPython you can use the urequests module to send a POST request. Depending on which board you're using it may already be included, otherwise you can get it from here https://github.com/micropython/micropyt ... equests.py
Groovy3286
Post by Groovy3286 » Mon Jul 04, 2022 2:19 pm
This looks like a lot more code than I've seen either on this forum, or just other websites in general.
url = ''
headers = {'Temperature': temp, 'Humidity' : hum}
data = hum, temp
r = requests.post(url, data=data, headers=headers)
results = r.json()
print(results)
This is what i've got right now, what I am super confused on is how to send directly to an IP address. Is is just IP:Port/file path.
Also confused on how I would input the data directly from the sensor to the DB, and how I would format data and headers. Sorry if im not making sense just been confused on this for super long and have looked at every single page regarding this lol
Post by jimmo » Mon Jul 04, 2022 2:40 pm
Not quite sure what you mean by this? Can you give an example.
The "url" here is where you put the ip and port (and path)... e.g. "http://192.168.1.100:12345/write?db=mydb"
So to translate that first example:
import urequests
url = "http://192.168.1.100:12345/write?db=mydb"
data = "'cpu_load_short,host=server01,region=us-west value=0.64 1434055562000000000'"
r = requests.post(url, data=data)
print(r.json())
FYI urequests on the MicroPython device should work exactly the same as "requests" in regular Python, so definitely easier to get this working on your PC first.
I don't know much about influxdb, but that link gives a pretty good example of how to combine measurement, tag keys, etc into the string above.
and headers
Based on that example, I don't think any headers are required.
There's a lot of different concepts here!!! It's definitely worth trying to understand one thing at a time -- try getting this working in regular Python then move it to MicroPython.
The key thing to understand is the HTTP protocol, how posting data works etc. Influx has a particularly simple use of post (there's no complicated encoding or anything, I suspect a lot of other guides about HTTP are making this sound more complicated).
Groovy3286
Post by Groovy3286 » Mon Jul 04, 2022 2:58 pm
viewtopic.php?t=5496 For example, on here. It shows a relatively short piece of code to send data to a URL.
Ok that makes sense thank you, was looking around and saw you had to use a file directory as well as the IP and port just wanted confirmation.
I saw that it was pretty similar to normal python when I was researching it, but the main thing I'm confused on is just getting it to send the raw output of the DHT22.
Definitely making it sound more complicated lol, i've seen tons of other ways of doing this and they are all slightly similar, but vastly different. It's what was mainly making me confused earlier.
