I am about to buy a new ESP32 board which does not have CP2102 interface. I will have to buy a USB to TTL serial adaptor. My question is - Can I use an ESP32 board with the UART-USB pass-through example https://docs.micropython.org/en/latest/ ... rough.html instead of a serial adaptor to program the new board?
Use ESP32 Board to Program Another EPS32
Re: Use ESP32 Board to Program Another EPS32
Potentially yes, but it will be much more convenient to get a USB/UART adaptor (e.g. FTDI), and just a handy thing to have in your electronics toolbox.Phisatho wrote: ↑Mon Jul 18, 2022 9:36 amI am about to buy a new ESP32 board which does not have CP2102 interface. I will have to buy a USB to TTL serial adaptor. My question is - Can I use an ESP32 board with the UART-USB pass-through example https://docs.micropython.org/en/latest/ ... rough.html instead of a serial adaptor to program the new board?
One thing the ESP32 boards with built-in CP2102 (or equivalent) do is use the RTS/CTS lines to toggle the bootloader. This will not be possible using an ESP32 as an adaptor.
I have a couple of adaptors in my drawer where I live. At the moment, I am in my home country.
So, to use ESP32 as the adaptor to flash micropython, will pressing the boot button before flashing do the job?
I haven't tried it, but yes I would imagine this should be possible.
Thanks. I will give it a try and report later.
