int() Anomaly
Re: int() Anomaly
This seemed to work for someone on the Raspberry Pi forum: Re: MicroPython double precision
Re: int() Anomaly
Thanks Peter,pythoncoder wrote: ↑Sun Jul 24, 2022 10:39 amI believe this is correct, but I haven't actually tried it.
Will give it a try as soon as I'm back. (Traveling right now)
Re: int() Anomaly
I built with micropython after applying #define MICROPY_FLOAT_IMPL (MICROPY_FLOAT_IMPL_DOUBLE) as thesilverbullet and can confirm that the "anomaly" has disappeared.
Re: int() Anomaly
Nice. But rest assured, the ›anomaly‹ hasn't disappeared, it has been shift from the seventh to the seventeenth digit. Not as visible as before.
print(f'{1.0/9.0:.30f}')
0.111111111111111104943205418749
Re: int() Anomaly
This isn't an "anomaly". It is quite normal that the precision of floats is limited.TheSilverBullet wrote: ↑Mon Jul 25, 2022 12:16 pmNice. But rest assured, the ›anomaly‹ hasn't disappeared, it has been shift from the seventh to the seventeenth digit
For more precision, you can use the integers (in micropython with arbitrary size).
A few hours of debugging might save you from minutes of reading the documentation!
Re: int() Anomaly
Trust me, I know precisely what it is. IEEE knows it as well. They have the 754…karfas wrote: ↑Mon Jul 25, 2022 3:01 pmThis isn't an "anomaly". It is quite normal that the precision of floats is limited.TheSilverBullet wrote: ↑Mon Jul 25, 2022 12:16 pmNice. But rest assured, the ›anomaly‹ hasn't disappeared, it has been shift from the seventh to the seventeenth digit
Re: int() Anomaly
So we have 16 significant digits at least in this little test:
With CPython:
With Micropython at Teensy 4.x, PyBoard D SF6 and rp2, compiled with double precision:
0.11111111111111111604543566500
With CPython:
Re: int() Anomaly
Exactly!
16 significant decimal digits which translates to a binary mantissa of size:
ln(10) / ln(2) * 16 = 53,…
And those 53 binary digits/bits, combined with 11 binary digits/bits as exponent are what's defines as double precision floats.
The important part is:
It is absolutely impossible to represent certain fractions in binary notation.
Pretty much the same way as it's impossible to represent certain decimal fractions.
But a ›double‹ resolution variable is 2^19 times better/more precise than a regular ›float‹ variable.
And that's a significant improvement, if really needed. Because at the same time it might be a bit slower.
Re: int() Anomaly
Let me add that the binary representation of that number is the same with CPython and MicroPython. Only the printed results differ in the part, which is anyhow not significant.
Re: int() Anomaly
Between single precision and double precision, the underlying representation itself differs - not just the displaying format. In my case, it was significant. I was trying to subtract a fractional offset from NTP_OFFSET. The conversion error caused 88 seconds difference.
