I have maded schema of two MCP23017 IO expanders, connected to I2C with 4.7K pullup resistors, tested it on ESP8266 with NodeMCU LUA, they work fine
now decided to try them on one WT32 board. Hardware I2C pins are used here for intergrated LAN, so I decide to try software I2C
after lot of failures, one of the MCPs start to show when I used pin 12 and pin 14, other MCP chip do not show up, If I remove working chip, other one apper in i2c.scan() function
I tried to change frequency, no effect.
Anyone succeed using software I2C on more than one device, using non standart pins?
MicroPython v1.19.1 on 2022-06-18; ESP32 module with ESP32
>>> from machine import Pin, SoftI2C
>>> i2c = SoftI2C(scl=Pin(14), sda=Pin(12), freq=100000)
