ENOMEM when sending request
jairov96
Post by jairov96 » Sun Aug 07, 2022 12:13 pm
Hello!
As you are most likely about to see, efficient code is not quite my thing. Coding isn't either, but I try :lol:
Running in an ESP-Wroom-32
I'm running into some issues where my code permanently returns "ENOMEM" error codes when trying to run the function sendPostRequest()
pastecode
from time import sleep
import ntptime
import urequests
import ujson
from machine import I2C, Pin
import BMP280
import gc
# Functions
def set_ntp_time():
    # This sets the esp32 time to be accurate using Network Time Protocol.
    ntptime.host = "1.europe.pool.ntp.org"
    ntptime.settime()
    del (ntptime.host)
def turn_on_bmp280():
        i2c = I2C(1, scl=Pin(22), sda=Pin(21), freq=10000)
        bmp = BMP280.BMP280(i2c)
        print("sensor connected")
        return (bmp)
    except Exception as e:
        print("Error: ", e)
def send_influx_measurement(
        endpoint,
        api_key,
        device_name,
        sensor_name,
        sensor_location,
        measurement):
    influx_measurement = "weather"
    timestamp = time.time_ns() + 946684800000000000  # add 30 years in ns
    headers = {}
    headers['Authorization'] = 'Token %s' % api_key
    body = "{},device={},sensor={},location={} temperature={} {}".format(
            influx_measurement,
            device_name,
            sensor_name,
            sensor_location,
            measurement,
            timestamp)
    print(body)
    sendPostRequest(endpoint, headers, body)
def sendPostRequest(url, headers, data):
        response = urequests.post(url, headers=headers, data=data)
        if response.status_code != 204:
            print("Request was not successful: ", response.status_code)
        print("Error sending request:", e)
    del (response)
# Main
def main():
    with open('configuration.json') as rawJson:
        configuration = ujson.loads(rawJson.read())
        submit_interval = configuration.get("submit_interval")
        influx_db_endpoint = configuration.get("influx_db_endpoint")
        influx_db_api_key = configuration.get("influx_db_api_key")
        device_name = configuration.get("device_name")
        sensor_name = configuration.get("sensor_name")
        sensor_location = configuration.get("sensor_location")
    set_ntp_time()
    sensor = turn_on_bmp280()
    while sensor:
            print("\nfree mem: ", gc.mem_free())
                    influx_db_endpoint,
                    influx_db_api_key,
                    device_name,
                    sensor_name,
                    sensor_location,
                    sensor.temperature)
            print("free mem after request: ", gc.mem_free())
            sleep(float(submit_interval))
            print("Error: ", e)
            print("Memory collected by gc = ", gc.collect())
            # machine.reset()
main()
Clearly, I am doing something wrong. Because usually it takes 2 runs of the while sensor loop to run in to the enomem issue, see this log for example:
Connection successful
('192.168.2.96', '255.255.255.0', '192.168.2.1', '192.168.2.20')
sensor connected
free mem:  88656
weather,device=ESP32_up2,sensor=bmp280,location=outside temperature=32.38 1659874123232696000
free mem after request:  84912
free mem:  84896
weather,device=ESP32_up2,sensor=bmp280,location=outside temperature=32.37 1659874129273187000
Error sending request: [Errno 12] ENOMEM
Collect empty memory None
free mem after request:  96016
I have the feeling that there is no space to return the response from urequests.post, but I already tried to remove the "response = [...]" assignment without success.
Any hints will be welcome!
jairov96
Re: ENOMEM when sending request
Post by jairov96 » Sun Aug 07, 2022 3:32 pm
Turns out the only thing I need to do in order to fix a problem is post it in the forum.
After a bit of tinkering I figured that it's a good practice to actually close the response!
        response.close()
        return
A very simple detail that at least for now It's making my code operational without reaching the limit of memory.
