ENOMEM when sending request
Posted: Sun Aug 07, 2022 12:13 pm
Hello!
As you are most likely about to see, efficient code is not quite my thing. Coding isn't either, but I try
Running in an ESP-Wroom-32
I'm running into some issues where my code permanently returns "ENOMEM" error codes when trying to run the function sendPostRequest()
pastecode
Clearly, I am doing something wrong. Because usually it takes 2 runs of the while sensor loop to run in to the enomem issue, see this log for example:
I have the feeling that there is no space to return the response from urequests.post, but I already tried to remove the "response = [...]" assignment without success.
Any hints will be welcome!
pastecode
from time import sleep
import ntptime
import urequests
import ujson
from machine import I2C, Pin
import BMP280
import gc
# Functions
def set_ntp_time():
# This sets the esp32 time to be accurate using Network Time Protocol.
ntptime.host = "1.europe.pool.ntp.org"
ntptime.settime()
del (ntptime.host)
def turn_on_bmp280():
i2c = I2C(1, scl=Pin(22), sda=Pin(21), freq=10000)
bmp = BMP280.BMP280(i2c)
print("sensor connected")
return (bmp)
except Exception as e:
print("Error: ", e)
def send_influx_measurement(
endpoint,
api_key,
device_name,
sensor_name,
sensor_location,
measurement):
influx_measurement = "weather"
timestamp = time.time_ns() + 946684800000000000 # add 30 years in ns
headers = {}
headers['Authorization'] = 'Token %s' % api_key
body = "{},device={},sensor={},location={} temperature={} {}".format(
influx_measurement,
device_name,
sensor_name,
sensor_location,
measurement,
timestamp)
print(body)
sendPostRequest(endpoint, headers, body)
def sendPostRequest(url, headers, data):
response = urequests.post(url, headers=headers, data=data)
if response.status_code != 204:
print("Request was not successful: ", response.status_code)
print("Error sending request:", e)
del (response)
# Main
def main():
with open('configuration.json') as rawJson:
configuration = ujson.loads(rawJson.read())
submit_interval = configuration.get("submit_interval")
influx_db_endpoint = configuration.get("influx_db_endpoint")
influx_db_api_key = configuration.get("influx_db_api_key")
device_name = configuration.get("device_name")
sensor_name = configuration.get("sensor_name")
sensor_location = configuration.get("sensor_location")
set_ntp_time()
sensor = turn_on_bmp280()
while sensor:
print("\nfree mem: ", gc.mem_free())
influx_db_endpoint,
influx_db_api_key,
device_name,
sensor_name,
sensor_location,
sensor.temperature)
print("free mem after request: ", gc.mem_free())
sleep(float(submit_interval))
print("Error: ", e)
print("Memory collected by gc = ", gc.collect())
# machine.reset()
main()
Connection successful
('192.168.2.96', '255.255.255.0', '192.168.2.1', '192.168.2.20')
sensor connected
free mem: 88656
weather,device=ESP32_up2,sensor=bmp280,location=outside temperature=32.38 1659874123232696000
free mem after request: 84912
free mem: 84896
weather,device=ESP32_up2,sensor=bmp280,location=outside temperature=32.37 1659874129273187000
Error sending request: [Errno 12] ENOMEM
Collect empty memory None
free mem after request: 96016
