Help with VSCode Stubs and Linter
Posted: Thu Sep 29, 2022 3:17 pm
I am a beginner and am having trouble getting the the micropython stubs and the Pylint extension to work properly
I am developing on an esp32 devkit and using VSCode and trying to use the stubs found here
https://micropython-stubs.readthedocs.i ... stubs.html
I have the most recent stub code from gethub and have used the pip install command to install the correct version of the stubs to my workspace. When I open any project file in my workspace almost every line of code gets marked with a "problem" when I know the code runs properly. I have been trying to find a solution to this online for a little while and have not found anything that works.
As for the linter I installed the Pylint extension is VSCode. I believe Pylint is supposed to have active linting, but it does not do anything for me. Even when I try to use the "run linter" command when I intentionally put spacing mistakes in my code nothing seems to happen. It does not give me any kind of error either, just nothing happens. I have tried reloading the VSCode window and restarting the Pylint server but neither fixed the problem. I currently have Pylint version v2022.4.0 installed.
I am not sure if it helps but I am using micropython version 18. I am also unsure if the problems with the stubs and the linter have a related solution in anyway or not.
