Question about machine.idle()
Posted: Wed Jul 05, 2017 6:30 pm
The ESP32 is at the moment very power hungry. It needs between 140 to 180 mA.
And that is far too much for battery powered devices.
So I try to tame the power consumption , without success.
ESP firmware here is the latest (branch esp32, commit message: esp32: Update to latest ESP-IDF)
Currently in esp32 firmware in modmachine,c the machine.idle() is implemented as:
STATIC mp_obj_t machine_idle(void) {
taskYIELD();
return mp_const_none;
With next snippet I tested the current firmware:
now = time.ticks_ms()
count = 0
while count < 1000:
machine.idle()
count += 1
now1 = time.ticks_ms()
diff = now1- now
print("1000 loops in %s ms. Per loop %s ms" %( diff, diff/1000) )
result: 1000 loops in 20 ms. Per loop 0.02 ms
Quite fast indeed!
I replaced the code with the code as found in the esp8266:
uint32_t t = mp_hal_ticks_cpu();
asm("waiti 0");
t = mp_hal_ticks_cpu() - t;
return MP_OBJ_NEW_SMALL_INT(t);
build and flashed the firmware.
Tested with same python snippet as above.
Result: 1000 loops in 9912 ms. Per loop 9.912 ms
This shows that the cpu really sleeps 10 ms at each machine.idle(). So far so good
(apparently there is a timer interrupt each 10 ms. Heartbeat of underlying RTOS?)
But even with the CPU idle, the power consumption stays exactly the same.
So whats wrong or missing here?
taskYIELD();
count = 0
while count < 1000:
machine.idle()
count += 1
diff = now1- now
Quite fast indeed!
asm("waiti 0");
