MicroPython on ESP32 with SPIRAM support
Re: MicroPython on ESP-WROVER with 4MB of psRAM
@loboris :
Thanks a lot for such great work.
i just tried to clone the repository and did a first call to BUILD.sh :
[code]
patrickpollet@patrickpollet-VirtualBox:~/esp32psram/MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD$ ./BUILD.sh menuconfig
unpacking 'esp-idf'
unpacking 'esp-idf_psram'
unpacking 'xtensa-esp32-elf'
unpacking 'xtensa-esp32-elf_psram'
Building MicroPython for ESP32 with esp-idf master branch
DEFCONFIG
/home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/conf: 1: /home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/conf: Syntax error: ")" unexpected
'make menuconfig' FAILED!
[/code]
But there was an error, i did a retry and got a different error :
[code]
MENUCONFIG
/home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/mconf: 1: /home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/mconf: Syntax error: "(" unexpected
[/code]
I do not know what to do, any help will be really appreciate.
Best regards.
Patrick
[code]
unpacking 'esp-idf'
DEFCONFIG
[/code]
[code]
MENUCONFIG
[/code]
Best regards.
Patrick
@loboris :
____________________
unpacking 'esp-idf'
DEFCONFIG
MENUCONFIG
_____________________
Best regards.
Patrick
unpacking 'esp-idf'
DEFCONFIG
MENUCONFIG
Best regards.
Patrick
@loboris: Thanks for all the work and the documentation -- looking forward to testing.
I writed last loboris firmware, but when I verify memory in use, I see:
I don't use 4 MB of memory ....
Why ?
I have a ESP WROOM32 device...
I need to configure somethings (with ./BUILD.sh menuconfig) ?
>>> micropython.mem_info()
stack: 736 out of 15360
GC: total: 92032, used: 6720, free: 85312
No. of 1-blocks: 22, 2-blocks: 10, max blk sz: 366, max free sz: 5222
Why ?
What exactly is a problem?c.man wrote:I don't use 4 MB of memory ....
Why ?
You are using ESP-WROOM-32 module which does not have psRAM.
You have 92032 bytes of MicroPython heap of which 6720 bytes are used. That is what you can expect on start.
Do you expect to see more?
ok. thanks.
I wrong to buy esp32 version.
What version of ESP32 have psRAM ?
ALB32-WROVER modulec.man wrote:What version of ESP32 have psRAM ?
ESP32-WROVER module
Pycom W01 OEM Module
Pycom L01 OEM Module
ESP-WROVER-KIT v3 development board
Pycom LoPy development board
Pycom SiPy development board
It looks its the same issue reported herepatrick.pollet wrote:...I do not know what to do, any help will be really appreciate...
Plase read it, maybe it will help.
It certainly does. It sounds awesome - I look forward to trying itloboris wrote:...
@pythoncoder
I hope this answers your question.
Thanks.loboris wrote: It looks its the same issue reported here
I just restarted from scratch on a fresh installed Ubuntu 16 and it works fine.
