MicroPython on ESP32 with SPIRAM support
Re: MicroPython on ESP32 with SPIRAM support
I'm not shure how 32-bit toolchain ended in repository, sorry about that.
The 64-bit is now pushed, you can update using git pull.
After the update just delete your Tools/xtensa-esp32-elf directory, the new one (64-bit) will be unpacked on first run of BUILD.sh.
I have also uploaded the 32-bit toolchain (Tools/Linux/xtensa-esp32-elf_32bit.tar.xz), if anyone is using 32-bit Linux.
Later, I'll update the BUILD.sh script to automatically unpack the right toolchain depending on the Linux version.
It looks there is a bug in spi initialization, I'm working on it, hope to push the fix shortly.OutoftheBOTS_ wrote: ↑Fri Jan 05, 2018 8:52 amI tried to use my program that was running on last firmware and it wouldn't run on the new firmware. The SPI threw an error
Edit: The fix is pushed, but Im still working on adding some more funstions to SPI module...
In menuconfig use both core for MiroPython tasks is unchecked. I should leave this unchecked for psRAM boards but checked for non psRAM boards??
It makes almost no difference at the moment, it is there for the future development. I'll add the comment about that.OutoftheBOTS_ wrote: ↑Fri Jan 05, 2018 7:45 pmIn menuconfig use both core for MiroPython tasks is unchecked. I should leave this unchecked for psRAM boards but checked for non psRAM boards??
It is in no way related to psRAM.
There is also a bug in the deint() for the SPI it throws this error
OSError: error at deinitialization
How do I add a custom C-module?
I added it to SRC_C in components/microphython/component.mk.
It compiles, but does not get included in the firmware.
Code (with probably more headers than I need):
#include <stdio.h>
#include <sys/time.h>
#include <time.h>
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "rom/uart.h"
#include "esp_task_wdt.h"
#include "py/nlr.h"
#include "py/obj.h"
#include "py/mpstate.h"
#include "py/mphal.h"
#include "extmod/misc.h"
#include "lib/utils/pyexec.h"
#include "uart.h"
#include "sdkconfig.h"
// does nothing for now ...
STATIC mp_obj_t iot49_sleep_us(mp_obj_t arg) {
mp_int_t us = mp_obj_get_int(arg);
return mp_const_none;
MP_DEFINE_CONST_FUN_OBJ_1(iot49_sleep_us_obj, iot49_sleep_us);
STATIC const mp_rom_map_elem_t iot49_module_globals_table[] = {
{ MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_iot49) },
{ MP_ROM_QSTR(MP_QSTR_sleep_us), MP_ROM_PTR(&iot49_sleep_us_obj) },
STATIC MP_DEFINE_CONST_DICT(
iot49_module_globals,
const mp_obj_module_t mp_module_iot49 = {
.base = { &mp_type_module },
.globals = (mp_obj_dict_t*)&iot49_module_globals,
If you look at the end of mpconfigport.h, there is a section where the modules a listed. You may add your module there, taking one of the existing definitions as template.
To add your c-module mp_module_iot49 to the built-in modeles edit the mpconfigport.h:
Add before #define MICROPY_PORT_BUILTIN_MODULES
extern const struct _mp_obj_module_t mp_module_iot49;
#define BUILTIN_MODULE_IOT49 { MP_OBJ_NEW_QSTR(MP_QSTR_iot49), (mp_obj_t)&mp_module_iot49 },
BUILTIN_MODULE_IOT49 \
./BUILD.sh clean all
@roberthh and @loboris: Thanks a million, everything works now as expected!
Bernhard Boser
