vfs_native warnings are normal on first start when no FatFS formated partition is detected.slzatz wrote:Do I need to do address the vfs_native warnings?
The partition is formated and mounted and there will be no more warnings on the next reboot.
The GSM module and PPPoS support is working, but still under testing. It will be enabled soon.cable134 wrote:... I've remarked that you implemented new module functionality as "GSM module and PPPoS support" (MICROPY_USE_GSM).
Is it ready for testing?...
import display
tft = display.TFT()
tft.init(tft.ILI9341, miso=19, mosi=18, clk=5, cs=15, dc=33, bgr=True)
>>> import network
W (13248) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
Brownout detector was triggered
The warning message is not an error, it will appear only on the first boot, then wifi callibration data are saved to the NVS memory.patrick.pollet wrote:... then i had a never seen before problem :Code: Select all
>>> import network W (13248) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration Brownout detector was triggered
