Page 35 of 47
Re: MicroPython on ESP32 with SPIRAM support
Posted: Sun Feb 04, 2018 5:40 pm
by kevinkk525
Thanks for the advice, here's the output:
beacon timeout
Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
Core 0 register dump:
PC : 0x40008544 PS : 0x00060f34 A0 : 0x80094804 A1 : 0x3ffda4f0
A2 : 0x000001e0 A3 : 0xf92561dc A4 : 0x00000001 A5 : 0x3ffd0404
A6 : 0x00000001 A7 : 0x3ffcc418 A8 : 0x80008547 A9 : 0x3ffda4e0
A10 : 0x000000a3 A11 : 0x00000000 A12 : 0x00000078 A13 : 0x401530f0
0x401530f0: ieee80211_rfid_locp_recv at ??:?
A14 : 0x40153d70 A15 : 0x3ffcc3a4 SAR : 0x0000001e EXCCAUSE: 0x00000005
0x40153d70: scan_inter_channel_timeout_process at ??:?
EXCVADDR: 0x00000000 LBEG : 0x4009e018 LEND : 0x4009e046 LCOUNT : 0xffffffff
0x4009e018: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:168
0x4009e046: memcpy at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memcpy.S:201
Backtrace: 0x40008544:0x3ffda4f0 0x40094801:0x3ffda510 0x40092af6:0x3ffda530 0x4009479d:0x3ffda550 0x40090b7d:0x3ffda570 0x40155ffb:0x3ffda590 0x4015603d:0x3ffda5c0 0x401560db:0x3ffda5e0 0x40153d09:0x3ffda600 0x40153d2b:0x3ffda640 0x40155c6f:0x3ffda660 0x40155d5e:0x3ffda680 0x40160a16:0x3ffda6a0
0x40094801: chip_sleep_prot_en at ??:?
0x40092af6: chip_v7_set_chan at ??:?
0x4009479d: set_chanfreq at ??:?
0x40090b7d: phy_change_channel at ??:?
0x40155ffb: chm_set_current_channel at ??:?
0x4015603d: chm_set_current_channel at ??:?
0x401560db: chm_start_op at ??:?
0x40153d09: free_bss_info at ??:?
0x40153d2b: scan_enter_oper_channel_process at ??:?
0x40155c6f: wifi_station_stop at ??:?
0x40155d5e: ieee80211_timer_do_process at ??:?
0x40160a16: ppTask at ??:?
Core 1 register dump:
PC : 0x400d675e PS : 0x00060234 A0 : 0x8008dd08 A1 : 0x3ffd57e0
0x400d675e: esp_vApplicationIdleHook at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/esp32/./freertos_hooks.c:85
A2 : 0x00000008 A3 : 0x00000001 A4 : 0x00000001 A5 : 0x3ffd5310
A6 : 0x00000000 A7 : 0x00000001 A8 : 0x3ffca20c A9 : 0x3ffca1d0
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x8008cc1b A13 : 0x3ffd56f0
A14 : 0x00000003 A15 : 0x00060023 SAR : 0x00000000 EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x400d675e:0x3ffd57e0 0x4008dd05:0x3ffd5800
0x4008dd05: prvIdleTask at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/freertos/./tasks.c:4702
CPU halted.
Posted: Sun Feb 04, 2018 7:56 pm
by loboris
@kevinkk525
I'll try to analyze this, it looks that the error occurs somewhere in the wifi library (no sources), so it won't be easy...
Have you changed anything from the default configuration?
Posted: Sun Feb 04, 2018 8:04 pm
by kevinkk525
I changed some things but nothing that could be a problem here (but who knows...). Just components, psram heap..
I think putting sdkconfig here would be easier? I removed the parts that I definitely did not change (but left some unchanged in there as well, just in case).
# MicroPython
CONFIG_MICROPY_USE_OTA=
# System settings
CONFIG_MICRO_PY_LOG_LEVEL=2
CONFIG_MICRO_PY_LOG_LEVEL0=
CONFIG_MICRO_PY_LOG_LEVEL1=
CONFIG_MICRO_PY_LOG_LEVEL2=y
CONFIG_MICRO_PY_LOG_LEVEL3=
CONFIG_MICRO_PY_LOG_LEVEL4=
CONFIG_MICRO_PY_LOG_LEVEL5=
CONFIG_MICROPY_RX_BUFFER_SIZE=1080
CONFIG_MICROPY_USE_TASK_WDT=y
CONFIG_MICROPY_USE_BOTH_CORES=y
CONFIG_MICROPY_TASK_PRIORITY=5
CONFIG_MICROPY_STACK_SIZE=20
CONFIG_MICROPY_HEAP_SIZE=3400
CONFIG_MICROPY_THREAD_MAX_THREADS=4
CONFIG_MICROPY_THREAD_STACK_SIZE=4
CONFIG_MICROPY_USE_TELNET=y
CONFIG_MICROPY_USE_WEBSERVER=
CONFIG_MICROPY_USE_FTPSERVER=y
# FTP Server Configuration
CONFIG_FTPSERVER_LOG_LEVEL=1
CONFIG_FTPSERVER_LOG_LEVEL0=
CONFIG_FTPSERVER_LOG_LEVEL1=y
CONFIG_FTPSERVER_LOG_LEVEL2=
CONFIG_FTPSERVER_LOG_LEVEL3=
CONFIG_FTPSERVER_LOG_LEVEL4=
CONFIG_MICROPY_FTPSERVER_TIMEOUT=300
CONFIG_MICROPY_FTPSERVER_BUFFER_SIZE=1024
# Modules
CONFIG_MICROPY_PY_FRAMEBUF=y
CONFIG_MICROPY_PY_USE_BTREE=
CONFIG_MICROPY_USE_WEBSOCKETS=y
CONFIG_MICROPY_USE_DISPLAY=y
CONFIG_MICROPY_USE_EVE=
CONFIG_MICROPY_USE_GSM=
CONFIG_MICROPY_USE_ETHERNET=
CONFIG_MICROPY_USE_MDNS=y
CONFIG_MICROPY_USE_CURL=
CONFIG_MICROPY_USE_SSH=
CONFIG_MICROPY_USE_MQTT=y
# File systems
CONFIG_MICROPY_FATFS_MAX_OPEN_FILES=6
CONFIG_MICROPY_USE_SPIFFS=y
CONFIG_MICROPY_SDMMC_SHOW_INFO=y
# SD Card configuration
CONFIG_SDCARD_MODE=3
CONFIG_SDCARD_MODE1=
CONFIG_SDCARD_MODE2=
CONFIG_SDCARD_MODE3=y
# Component config
# Bluetooth
CONFIG_BT_ENABLED=y
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_0=y
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE_1=
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BTDM_CONTROLLER_HCI_MODE_VHCI=y
CONFIG_BTDM_CONTROLLER_HCI_MODE_UART_H4=
CONFIG_BLUEDROID_ENABLED=y
CONFIG_BLUEDROID_PINNED_TO_CORE_0=y
CONFIG_BLUEDROID_PINNED_TO_CORE_1=
CONFIG_BLUEDROID_PINNED_TO_CORE=0
CONFIG_BTC_TASK_STACK_SIZE=3072
CONFIG_BLUEDROID_MEM_DEBUG=
CONFIG_CLASSIC_BT_ENABLED=
CONFIG_GATTS_ENABLE=y
CONFIG_GATTC_ENABLE=y
CONFIG_BLE_SMP_ENABLE=y
CONFIG_BT_STACK_NO_LOG=
CONFIG_BT_ACL_CONNECTIONS=4
CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST=
CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY=
CONFIG_SMP_ENABLE=y
CONFIG_BT_RESERVE_DRAM=0x10000
# ESP32-specific
CONFIG_ESP32_DEFAULT_CPU_FREQ_80=
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_MEMMAP_SMP=y
CONFIG_SPIRAM_SUPPORT=y
# SPI RAM config
CONFIG_SPIRAM_BOOT_INIT=y
CONFIG_SPIRAM_USE_MEMMAP=
CONFIG_SPIRAM_USE_CAPS_ALLOC=y
CONFIG_SPIRAM_USE_MALLOC=
CONFIG_SPIRAM_TYPE_ESPPSRAM32=y
CONFIG_SPIRAM_SIZE=4194304
CONFIG_SPIRAM_SPEED_40M=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST=
CONFIG_MEMMAP_TRACEMEM=
CONFIG_MEMMAP_TRACEMEM_TWOBANKS=
CONFIG_ESP32_TRAX=
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH=
CONFIG_ESP32_ENABLE_COREDUMP_TO_UART=
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_ESP32_ENABLE_COREDUMP=
CONFIG_TWO_UNIVERSAL_MAC_ADDRESS=
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=2048
CONFIG_MAIN_TASK_STACK_SIZE=3584
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF=
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_LF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
CONFIG_NEWLIB_NANO_FORMAT=
CONFIG_CONSOLE_UART_DEFAULT=y
CONFIG_CONSOLE_UART_CUSTOM=
CONFIG_CONSOLE_UART_NONE=
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_ULP_COPROC_ENABLED=
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_ESP32_PANIC_PRINT_HALT=y
CONFIG_ESP32_PANIC_PRINT_REBOOT=
CONFIG_ESP32_PANIC_SILENT_REBOOT=
CONFIG_ESP32_PANIC_GDBSTUB=
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=300
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_PANIC=
CONFIG_TASK_WDT_TIMEOUT_S=15
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_BROWNOUT_DET=
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC=
CONFIG_ESP32_TIME_SYSCALL_USE_FRC1=
CONFIG_ESP32_TIME_SYSCALL_USE_NONE=
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL=
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_XTAL_FREQ_40=
CONFIG_ESP32_XTAL_FREQ_26=
CONFIG_ESP32_XTAL_FREQ_AUTO=y
CONFIG_ESP32_XTAL_FREQ=0
CONFIG_DISABLE_BASIC_ROM_CONSOLE=
CONFIG_ESP_TIMER_PROFILING=
CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS=
# Wi-Fi
CONFIG_SW_COEXIST_ENABLE=
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=8
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
# PHY
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION=y
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# Ethernet
CONFIG_DMA_RX_BUF_NUM=10
CONFIG_DMA_TX_BUF_NUM=10
CONFIG_EMAC_L2_TO_L3_RX_BUF_MODE=
CONFIG_EMAC_TASK_PRIORITY=20
# FreeRTOS
CONFIG_FREERTOS_UNICORE=
CONFIG_FREERTOS_CORETIMER_0=y
CONFIG_FREERTOS_CORETIMER_1=
CONFIG_FREERTOS_HZ=1000
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK=
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=4
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE=
CONFIG_FREERTOS_ASSERT_DISABLE=
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1024
CONFIG_FREERTOS_ISR_STACKSIZE=4096
CONFIG_FREERTOS_LEGACY_HOOKS=
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_SUPPORT_STATIC_ALLOCATION=y
CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK=y
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
CONFIG_FREERTOS_USE_TRACE_FACILITY=
CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=
CONFIG_FREERTOS_DEBUG_INTERNALS=
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
CONFIG_HEAP_POISONING_LIGHT=
CONFIG_HEAP_POISONING_COMPREHENSIVE=
CONFIG_HEAP_TRACING=
# libsodium
# Log output
CONFIG_LOG_DEFAULT_LEVEL_NONE=
CONFIG_LOG_DEFAULT_LEVEL_ERROR=
CONFIG_LOG_DEFAULT_LEVEL_WARN=y
CONFIG_LOG_DEFAULT_LEVEL_INFO=
CONFIG_LOG_DEFAULT_LEVEL_DEBUG=
CONFIG_LOG_DEFAULT_LEVEL_VERBOSE=
CONFIG_LOG_DEFAULT_LEVEL=2
CONFIG_LOG_COLORS=y
# LWIP
CONFIG_L2_TO_L3_COPY=
CONFIG_LWIP_MAX_SOCKETS=8
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_IP_FRAG=
CONFIG_LWIP_IP_REASSEMBLY=
CONFIG_LWIP_STATS=
CONFIG_LWIP_ETHARP_TRUST_IP_MAC=y
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=y
# DHCP server
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
CONFIG_LWIP_AUTOIP=
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_TCP_OVERSIZE_MSS=y
CONFIG_TCP_OVERSIZE_QUARTER_MSS=
CONFIG_TCP_OVERSIZE_DISABLE=
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=4096
CONFIG_PPP_SUPPORT=y
CONFIG_PPP_PAP_SUPPORT=y
CONFIG_PPP_CHAP_SUPPORT=
CONFIG_PPP_MSCHAP_SUPPORT=
CONFIG_PPP_MPPE_SUPPORT=
CONFIG_PPP_DEBUG_ON=
# ICMP
CONFIG_LWIP_MULTICAST_PING=
CONFIG_LWIP_BROADCAST_PING=
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# mbedTLS
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=16384
CONFIG_MBEDTLS_DEBUG=
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_MPI_USE_INTERRUPT=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_HAVE_TIME=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
CONFIG_MBEDTLS_TLS_SERVER_ONLY=
CONFIG_MBEDTLS_TLS_CLIENT_ONLY=
CONFIG_MBEDTLS_TLS_DISABLED=
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# PThreads
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
# SPI Flash driver
CONFIG_SPI_FLASH_VERIFY_WRITE=
CONFIG_SPI_FLASH_ENABLE_COUNTERS=
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS=
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=1
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
CONFIG_SPIFFS_CACHE_STATS=
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
CONFIG_SPIFFS_GC_STATS=
CONFIG_SPIFFS_OBJ_NAME_LEN=64
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=5
CONFIG_SPIFFS_USE_MTIME=y
CONFIG_SPIFFS_USE_DIR=y
# tcpip adapter
CONFIG_IP_LOST_TIMER_INTERVAL=120
Posted: Sun Feb 04, 2018 8:14 pm
by loboris
kevinkk525 wrote: ↑Sun Feb 04, 2018 8:04 pm
Why have you enabled the Bluetooth ? It is not supported (yet) and could potentially cause the problem.
Posted: Sun Feb 04, 2018 8:36 pm
by kevinkk525
oh ok. i'll turn it off and try again.
Posted: Sun Feb 04, 2018 10:18 pm
by kevinkk525
It occured even without bluetooth included but this time the trace has more information.
/home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/freertos/./queue.c:718 (xQueueGenericSend)- assert failed!
abort() was called at PC 0x4008c3a7 on core 1
0x4008c3a7: xQueueGenericSend at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/freertos/./queue.c:2037
Backtrace: 0x40090648:0x3ffcf9c0 0x4009080f:0x3ffcf9e0 0x4008c3a7:0x3ffcfa00 0x401309b9:0x3ffcfa40 0x40131ba2:0x3ffcfa60 0x401304c5:0x3ffcfaa0 0x40130664:0x3ffcfb70 0x40137275:0x3ffcfba0 0x400e070b:0x3ffcfbc0 0x400e13b5:0x3ffcfbe0 0x400d8d26:0x3ffcfc10
0x40090648: invoke_abort at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/esp32/./panic.c:648
0x4009080f: abort at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/esp32/./panic.c:648
0x401309b9: spiffs_api_unlock at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/spiffs/./esp_spiffs.c:434
0x40131ba2: SPIFFS_readdir at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/spiffs/spiffs/src/spiffs_hydrogen.c:1125
0x401304c5: vfs_spiffs_readdir_r at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/spiffs/./esp_spiffs.c:434
0x40130664: vfs_spiffs_readdir at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/spiffs/./esp_spiffs.c:434
0x40137275: readdir at /home/kevin/MicroPython_ESP32_psRAM_LoBo/Tools/esp-idf/components/vfs/./vfs.c:464
0x400e070b: ftp_list_dir at /home/kevin/MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD/components/micropython/esp32/libs/ftp.c:1265
0x400e13b5: ftp_run at /home/kevin/MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD/components/micropython/esp32/libs/ftp.c:1265
0x400d8d26: ftp_task at /home/kevin/MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD/components/micropython/esp32/mpthreadport.c:512
CPU halted.
EVE display module
Posted: Tue Feb 06, 2018 2:44 am
by cartere
loboris, status of the driver?
Any chance of a 'hello world' quick example, recently backed Gameduino 3 kickstarter would love to put Micropython on it.
Posted: Tue Feb 06, 2018 3:17 am
by ttmetro
@OutoftheBOTS_
https://github.com/bboser/iot-plot shows one approach to plot from an ESP32. Not tied to any particular (Micro)Python implementation.
Posted: Tue Feb 06, 2018 10:41 am
by OutoftheBOTS_
@ttmetro thanks for your response
I have been chipping away at it and have been using a webserver wrote by Jczic that is embedded in frozen byte code in laboris firmware see wiki
https://github.com/loboris/MicroPython_ ... icroWebSrv
I have also found an easy to use open source Java Script plotter that I feed the data to live via websockets see
http://smoothiecharts.org/
I have it all working but my html is very basic and my JavaScript is non existent so making it all pretty with fully featured of what I would like will take me awhile to nut out
Re: EVE display module
Posted: Tue Feb 06, 2018 11:01 am
by loboris
cartere wrote: ↑Tue Feb 06, 2018 2:44 am
Status of which driver exactly ?
Gameduino 3 is based on esp8266, isn't it ?
