MicroPython on ESP32 with SPIRAM support
patrick.pollet
Re: MicroPython on ESP-WROVER with 4MB of psRAM
Post by patrick.pollet » Sun Sep 03, 2017 11:49 am
@loboris :
Thanks a lot for such great work.
i just tried to clone the repository and did a first call to BUILD.sh :
[code]
patrickpollet@patrickpollet-VirtualBox:~/esp32psram/MicroPython_ESP32_psRAM_LoBo/MicroPython_BUILD$ ./BUILD.sh menuconfig
unpacking 'esp-idf'
unpacking 'esp-idf_psram'
unpacking 'xtensa-esp32-elf'
unpacking 'xtensa-esp32-elf_psram'
Building MicroPython for ESP32 with esp-idf master branch
DEFCONFIG
/home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/conf: 1: /home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/conf: Syntax error: ")" unexpected
'make menuconfig' FAILED!
[/code]
But there was an error, i did a retry and got a different error :
[code]
MENUCONFIG
/home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/mconf: 1: /home/patrickpollet/esp32psram/MicroPython_ESP32_psRAM_LoBo/esp-idf/tools/kconfig/mconf: Syntax error: "(" unexpected
[/code]
I do not know what to do, any help will be really appreciate.
Best regards.
Patrick
patrick.pollet
Post by patrick.pollet » Sun Sep 03, 2017 12:09 pm
@loboris :
____________________
unpacking 'esp-idf'
DEFCONFIG
MENUCONFIG
_____________________
Best regards.
Patrick
slzatz
Post by slzatz » Sun Sep 03, 2017 12:13 pm
@loboris: Thanks for all the work and the documentation -- looking forward to testing.
c.man
Post by c.man » Sun Sep 03, 2017 2:40 pm
I writed last loboris firmware, but when I verify memory in use, I see:
>>> micropython.mem_info()
stack: 736 out of 15360
GC: total: 92032, used: 6720, free: 85312
 No. of 1-blocks: 22, 2-blocks: 10, max blk sz: 366, max free sz: 5222
I don't use 4 MB of memory ....
Why ?
I have a ESP WROOM32 device...
I need to configure somethings (with ./BUILD.sh menuconfig) ?
loboris
Post by loboris » Sun Sep 03, 2017 3:12 pm
c.man wrote:I don't use 4 MB of memory ....
Why ?
What exactly is a problem?
You are using ESP-WROOM-32 module which does not have psRAM.
You have 92032 bytes of MicroPython heap of which 6720 bytes are used. That is what you can expect on start.
Do you expect to see more?
c.man
Post by c.man » Sun Sep 03, 2017 4:31 pm
ok. thanks.
I wrong to buy esp32 version.
What version of ESP32 have psRAM ?
loboris
Post by loboris » Sun Sep 03, 2017 8:28 pm
patrick.pollet wrote:...I do not know what to do, any help will be really appreciate...
It looks its the same issue reported here
Plase read it, maybe it will help.
Post by pythoncoder » Mon Sep 04, 2017 7:00 am
loboris wrote:...
@pythoncoder
I hope this answers your question.
It certainly does. It sounds awesome - I look forward to trying it :D
patrick.pollet
Post by patrick.pollet » Mon Sep 04, 2017 9:01 am
loboris wrote: It looks its the same issue reported here
Thanks.
I just restarted from scratch on a fresh installed Ubuntu 16 and it works fine.
