esp32 build error
Posted: Mon Jul 10, 2017 6:34 am
Hello everyone !
When build the esp32 firmware ,the error as follow:
/home/ubuntu/esp/esp-idf//components/esp32/ipc.c: In function 'esp_ipc_init':
/home/ubuntu/esp/esp-idf//components/esp32/ipc.c:83:58: error: 'CONFIG_IPC_TASK_STACK_SIZE' undeclared (first use in this function)
xTaskCreatePinnedToCore(ipc_task, task_names, CONFIG_IPC_TASK_STACK_SIZE, (void*) i,
/home/ubuntu/esp/esp-idf//components/esp32/ipc.c:83:58: note: each undeclared identifier is reported only once for each function it appears in
make: *** [build//home/ubuntu/esp/esp-idf//components/esp32/ipc.o] Error 1
How sloves this issue! Thank you!
