I'm curious about the PyCom LoPy device, does anyone have experience with them? It looks like you can run roughly the same Python code there as you can on an ordinary ESP32. They seem to be claiming far lower power draw though;
https://pycom.io/wp-content/uploads/201 ... st2017.pdf
- WiFi: 12mA in active mode, 5uA in standby
- Lora: 15mA in active mode, 10uA in standby
That's surprising, as I understand it the ESP32 consumes ~175mA when WiFi is transmitting? But then I guess this 12mA number may be when the device merely has WiFi enabled, not transmitting or receiving. Expensive though, about USD $100 for the device and the development expansion board. And if you want to experiment with LoRa you would need two.
pycom boards
Re: pycom boards
I have a LoPy board and it works so far. The power consumption numbers are possible, but only with a special shield that compensates for a design flaw, preventing ultra low power. That should be integrated in the recent expansion board, or comes with it.
The Python variants differ a bit. The communication modules (WiFi, Bluetooth and LoRa) are supported well.
The have also a forum at https://forum.pycom.io/, which discusses a lot the aspect of power consumption.
The price you mention is not valid. If you look at the pycom.io web shop https://pycom.io/webshop/, the LoPy comes at 30 €, the WiPy (which is more or less just a esp32 board) is tagged at 20 €, and so on.
Personally I have the impression, that the micropython port is a little bit more stable, but the pycom.io port offers more functionality.
Re: pycom boards
Thanks for the feedback. Not sure where I saw that price, may have been looking at the wrong thing. I assume I would need the LoPy, an expansion board, and probably the antenna? Have you tried communicating between two of the devices with LoRa radio?
Re: pycom boards
Actually I did not try that yet. But if you look into the pycom.io forum, it sounds as if communication between two LoPys is supported.
And yes, you need an external antenna for LoRa. The board antenna is for WiFi only.
Re: pycom boards
I tested two modules, a module as node and a module as gateway in Lora Lora mode.
Works really well with a range> 1 Km with trees and hills as obstacles.
tested in mode sf=7 gives a good transfer rate in bidirectional mode.
Re: pycom boards
Good to know. Thanks!
