Hello everyone,
I'm currently trying to get my HUZZAH32 to return me the current voltage of my connected battery.
As you see in the documentation from adafruit:
https://learn.adafruit.com/adafruit-huz ... /esp32-faq
GPIO35 is connected internally with a 100k ohms voltage divider to expose the current voltage.
(And it's properly connected - also on the board)
Now when I try to read out the value via ADC on pin 35 I get 4095 which is technically impossible. I measured the actual hardware voltage at pin 35 which was around 2.04V and is valid.
Now my question is, is there a bug inside the esp32 branch of micropython? Or did I simply forget to set something?
Thanks.
HUZZAH32 Battery Pin Strange Values
Re: HUZZAH32 Battery Pin Strange Values
Actually the issue was a wrong attenuation value at at the adc pin. It is defaulted from 0..1.1v.
See the github issue for more information: https://github.com/micropython/micropyt ... issues/173
