Hello!
Before I quick it off, congrats on this very useful software, very promising and thank you!
Ok, now I'm just getting started and running into some issues on Mac Sierra.
Here is what I get when I boot the board:
ets Jun 8 2016 00:22:57
flash read err, 1000
Falling back to built-in command interpreter.
OK
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0010,len:4
load:0x3fff0014,len:4268
load:0x40078000,len:0
load:0x40078000,len:10648
entry 0x4007a56c
I (983) cpu_start: Pro cpu up.
I (983) cpu_start: Single core mode
I (985) heap_init: Initializing. RAM available for dynamic allocation:
I (995) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (1013) heap_init: At 3FFD4158 len 0000BEA8 (47 KiB): DRAM
I (1033) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1052) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1073) heap_init: At 4008F3A8 len 00010C58 (67 KiB): IRAM
I (1092) cpu_start: Pro cpu start user code
I (1153) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.2-279-g090b6b80 on 2017-10-15; ESP32 module with ESP32
All the samples fail with error.
Here is what I did to get the board running:
esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 115200 erase_flash
esptool.py v2.1
Connecting........___
Chip is ESP32D0WDQ6 (revision 1)
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 0.9s
Hard resetting...
esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 115200 write_flash -z 0x1000 firmware.bin
esptool.py v2.1
Connecting........_
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 903392 bytes to 567400...
Wrote 903392 bytes (567400 compressed) at 0x00001000 in 50.1 seconds (effective 144.2 kbit/s)...
Hash of data verified.
esptool.py --port /dev/tty.SLAB_USBtoUART flash_id
esptool.py v2.1
Connecting........____
Detecting chip type... ESP32
Uploading stub...
Running stub...
Stub running...
Manufacturer: c8
Device: 4016
Detected flash size: 4MB
Hard resetting...
Fixed the boot issues, simply just reflashed at lower baud rate,
But I still get errors with the examples on the documentation:
>>>pyb.LED(1).on()
NameError: name 'pyb' is not defined
Here is the correct boot:
entry 0x4007a56c
I (982) cpu_start: Pro cpu up.
I (984) heap_init: Initializing. RAM available for dynamic allocation:
I (994) heap_init: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (1032) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1072) heap_init: At 4008F3A8 len 00010C58 (67 KiB): IRAM
I (1091) cpu_start: Pro cpu start user code
I (1152) cpu_start: Starting scheduler on PRO CPU.
Well, as I was typing this, I caught a OSError: [Errno 2] ENOENT... help?
Re: OSError: [Errno 2] ENOENT
The pyb module is specific to the Pyboard so cannot be imported on any other platform. You need to use machine on ESP32 (and other ports).
Hello, thank you for the feedback, that was not apparent to me.
I did try this though and it failed...
>>>import machine:
>>>pyb.LED(1).on()
Now I have to figure out how can I upload a simple main.py to the board to test it on a file, still learning the right flows but I'm more conformable than going through the IDE and C. .
>>>import machine:
>>>pyb.LED(1).on()
create the main.py file to remove the 'OSError: [Errno 2] ENOENT' and try this examples http://docs.micropython.org/en/latest/e ... ckref.html it's the documentation for esp8266 but the esp32 API is similar so you will be able to run most of the examples.
Thank you, figured things out, now I'm up and running... able to get Wifi, onboard LED, parsing text, and pretty much all my needs met, thank you Dev Team!
