I2C slave?
tuupola
I2C slave?
Post by tuupola » Fri Oct 20, 2017 6:20 pm
Looking at docs and source it seems ESP32 port does not support I2C slave mode? Pyboard seems to have support. Are there any plans on implementing it in ESP32 port in nearby future?
loboris
Re: I2C slave?
Post by loboris » Sat Oct 21, 2017 6:41 pm
I2C slave is supported in esp-idf.
I'm planning to add hardware I2C slave support in my Micropython port the next month.
devnull
Re: I2C slave?
Post by devnull » Sun Nov 19, 2017 6:47 am
Hi Loboris;
You mentioned that you were going to add the I2C Slave Mode, is this likely to happen any time soon ?
tuupola
Re: I2C slave?
Post by tuupola » Sun Nov 19, 2017 8:05 am
I played around with with esp-idf and created a couple of I2C slaves. They seem to work well. Only problem is though, that since ESP32 has hardware I2C implementation and there is only two I2C busses the slave can only listen at two I2C addresses. I do not know if there is a way around this other than creating a software I2C slave implementation.
In any case I also would be interested this supported in Micropython.
