Can't modify content in /flash directory via mpfshell on LoBo port.
water
Post by water » Wed Feb 14, 2018 8:58 pm
I success connected ESP-WROOM-32 via mpfshell, Micropython is "ESP32_LoBo_v3.1.18 - 2017-02-07" prebuilt firmware,
and success list ESP-32 file via "ls" command.
In /flash directory, I try to use "put xxx.xxx" to upload local machine file to ESP-32, but appear "Failed to create file: xxx.xxx", and use "get boot.py" to download boot.py to local machine from ESP-32, appear "Failed to read file: boot.py".
In /flash directory, use "md test" to create "test" directory and change to /flash/test directory, these operation ("put" and "get" file) above are success.
And other way, in Micropython shell, use this method like below is also success:
>>> f = open('/flash/boot.py')
>>> f.read()
This prebuilt firmware used SPIFFS with internal filesystem, is it mpfshell must required FAT filesystem? or /flash directory has some access permissions ?
loboris
Re: Can't modify content in /flash directory via mpfshell on LoBo port.
Post by loboris » Wed Feb 14, 2018 11:44 pm
I've tried with the same prebuilt firmware and it works fine.
boris@UbuntuMate:~$ mpfshell
** Micropython File Shell v0.8.1, sw@kaltpost.de **
-- Running on Python 2.7 using PySerial 3.4 --
mpfs [/]> open ttyUSB0
Connected to esp32
mpfs [ /flash]> ls
Remote files in '/flash':
 <dir> ..
       boot.py
mpfs [ /flash]> ls
 <dir> ..
       boot.py
mpfs [ /flash]> get boot.py
mpfs [ /flash]> put boot.py boot_copy.py
mpfs [ /flash]> ls
 <dir> ..
       boot.py
       boot_copy.py
mpfs [ /flash]> md test
mpfs [ /flash]> ls
 <dir> ..
 <dir> test
       boot.py
       boot_copy.py
mpfs [ /flash]> cd test
mpfs [ /flash/test]> ls
Remote files in '/flash/test':
 <dir> ..
mpfs [ /flash/test]> put boot.py
 <dir> ..
       boot.py
mpfs [ /flash/test]> repl
*** Exit REPL with Ctrl+] ***
MicroPython ESP32_LoBo_v3.1.18 - 2017-02-07 on ESP32 board with ESP32
mattyt
Post by mattyt » Fri Oct 19, 2018 1:19 am
Hi folks,
I've run into the same issue but it seems a problem only on Windows.
I'm using ESP32_LoBo_v3.2.24 - 2018-09-06 on an M5Stack Core (no PSRAM) with mpfshell 0.8.1. Using mpfshell to connect to this from a Linux host (Ubuntu 16.04) works fine; files can be transferred. Using the same version of mpfshell on Windows prevents files from being transferred in either direction:
$ python -m mp.mpfshell
-- Running on Python 3.6 using PySerial 3.4 --
mpfs [/]> open COM6
Connected to esp32_LoBo
mpfs [/flash_]> ls
 <dir> ..
       boot.py
mpfs [/flash_]> lls
Local files:
       test.py
mpfs [/flash_]> put test.py
Failed to create file: test.py
mpfs [/flash_]> get boot.py
I've used Dave Hyland's rshell and, after working around an issue running rshell on Windows, it connects and transfers files fine.
I would be inclined to say this is an mpfshell issue however there appears to be no problems with mainline MicroPython on Windows:
mpfs [/]> open COM9
Connected to esp32
mpfs [/]> get boot.py
mpfs [/]> lls
Local files:
       boot.py
In any case, we can use rshell as a work-around for now but it does seem that the Lobo fork is doing something different to mainline MicroPython and perhaps this is causing issues with mpfshell?
Boris, should I raise this as an issue on your issue tracker? Could it be a problem on the Lobo fork?
Post by OutoftheBOTS_ » Fri Oct 19, 2018 4:30 am
Yes as a windows user I also have problem with windows security blocking
mattyt
Post by mattyt » Fri Oct 19, 2018 4:34 am
I don't think this particular issue is due to security blocking - for two reasons. 1) I tried running the console as Administrator and 2) mainline MicroPython works fine.
Informatic0re
Post by Informatic0re » Fri Oct 22, 2021 3:00 pm
I am having the exact same issue on Windows but with an nRF52 and Micropython.
Somehow the initial upload if the file does not yet exist works but not if I try to upload it again. If I remove the file using mpfshell and try to upload again, I receive the error message "Failed to create file:" but it got uploaded.
Because I am using a script to upload multiple files and also create folders I added a command delete all files first and then upload them which seems to work, I do not receive the error anymore.
