Further images, including a schematic, on the Tindie link above.
A small issue is with the optional HTU21D temperature and humidity chip. While it works perfectly it is warmed by the adjacent ESP32 module, which affects its readings. This is probably inevitable on such a tiny board. I think the solution is to put the ESP32 into sleep mode for a period before taking a reading. Otherwise buy without the HTU21D and use an external HTU21D breakout (e.g. from Adafruit).
