I'm using the second and third UART on an ESP32 for a project. I keep getting a "uart: UART event queue full" when the UART is getting messages (loads of them from a sensor). Reading the UART seems to work fine regardless of the errors.
I'm using the following code to set it up, using boot.py
uart2 = UART(1, 9600)
uart2.init(9600, bits=8, parity=None, stop=1, rx=22, tx=23)
I read about setting the buffer size manually with buffer_size=1024, but that did not work for me:
>>> uart2.init(9600, bits=8, parity=None, stop=1, rx=22, tx=23, buffer_size=1024)
TypeError: extra keyword arguments given
I don't really know what I'm doing and would appreciate any tips you may have
Edit: Tried physics and multiplexed pins, simply typing into the RX-pin from a Putty terminal, updating the firmware and using another ESP32-Wroom on an ESP32 Devkit. I still keep getting these "W (59495) uart: UART event queue full" errors.
Re: UART event queue full
I am experiencing the same issue.
robox, have you found a solution yet?
Any help is appreciated!
[quote=m_joule post_id=26154 time=1521137297 user_id=3822]
[/quote]
I Have still not found a solution to this. It seems dpgeorge did an update to the UART-code a few days ago https://github.com/micropython/micropyt ... c42ed84cb8 but it doesn't seem to have solved the issue.
[/quote]
Also having the same issue. I'm trying to read from UART, and even when the esp32 receives a few bytes of data, I get:
W (211907) uart: UART event queue full
I just got the esp32, and I was really hoping that serial would work with micropython:
uart = UART(2, 9600)
uart.init(9600, bits=8, parity=None, stop=1)
a = uart.readline()
and as soon as a message comes in, i get the event queue full.
Also get the error after sending 11 newlines:
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> W (276375) uart: UART event queue full
Any help would be appreciated. I don't really need to send utf-8, but it's quick for testing. Is there a way to flush the buffer or something?
a = uart.readline()
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
>>> uart.write('\n')
1
So i figured out what the issue was...
I was sending serial data to the esp32 over 5v logic. Luckily, my buddy came by our shop, and dropped off some 3v to 5v logic switchers:
https://us.banggood.com/Wholesale-Wareh ... ssQAvD_BwE
These guys fixed the issue right up. Now I can serial send commands right into the repl, though that was not exactly what i was looking for. Duh, UART. *face palm. I'm still fairly new to serial in general, but I was hoping i could pull from the buffer, and use a byte string and python's pack and unpack function from the struct library to use that data to trigger functions in micropython, but this changes everything. long story short, pick up some 3v to 5v logic converters. I was able to send from micropython to my computer, without logic converters, but I could not receive serial from micropython without these logic converters.
I dont think we are facing the same issue. I've been using 3.3v logic all the time, and still have this problem. Have been using an ESP8266 without any issues. Going to try to compile micropython myself with lower error logging level and see if that works.
I have the same issue. After the event queue full message, I checked my serial port object:
I had it at 9600! There is some bug in the code. I am using lobo firmware and he said he made some fixes on 2/2/2018:
https://github.com/loboris/MicroPython_ ... /issues/50
My firmware is dated 3/21/2018 and should have the fix. The code I have was running inside main.py. When I was running it in serial REPL, there was no problem. Will write back when I have more information.
ser
UART(2, baudrate=768307, bits=3, parity=None, stop=1, tx=22, rx=23, rts=-1, cts=-1, timeout=0, buf_size=512, lineend=b'\r\n')
Event task minimum free stack: 0
@liudr
The uart boudrate is correct, only the value printed is wrong.
It is fixed in the latest update.
I have a script which produces this error on the official port. I haven't seen it on the Loboris port. There is no question of overvoltage as it simply uses a loopback. I have raised an issue.
