SDcard in SPI mode using Loboris port?
con3
Re: SDcard in SPI mode using Loboris port?
Post by con3 » Sun Jul 29, 2018 10:16 pm
liudr
Post by liudr » Mon Jul 30, 2018 5:12 am
Thanks con3.
I read that thread and tried internal pullup resistors (I already have external pullups) and that didn't work. So I started my own thread on lobo forum and worked out the problem to be the latest lobo firmware has a higher SPI speed than my board can take. I fell back to an earlier version that I happen to have saved back in March and it worked. I don't know the SPI speed for the March firmware but that must have been slow enough. At a default speed of 20MHz, maybe the multiplexer on ESP32 is not able to handle or my traces have one too many vias or I should have matched impedance on the traces etc.
Anyway, Lobo is making an update to include an SPI speed parameter in sdconfig(). Here is my thread:
https://loboris.eu/forum/showthread.php?tid=216
Hope anyone reading this find the information useful.
con3
Post by con3 » Mon Jul 30, 2018 11:20 am
hi liudr,
Glad you got it sorted!
Can't you change the speed on the SPI lines by changing the SPI baud rate to fit your required speed?
liudr
Post by liudr » Mon Jul 30, 2018 6:23 pm
hi liudr,
Not sure where that SPI speed setting is. I could have if I knew a bit more about how they created the whole MicroPython ecosystem.
