micropyGPS crashes my ESP32
Re: micropyGPS crashes my ESP32
Post by dhylands » Sun Apr 22, 2018 4:52 am
Also make sure that ground is connected between the GPS module and the microcontroller.
Post by pythoncoder » Sun Apr 22, 2018 8:58 am
cable134 wrote:
Sat Apr 21, 2018 9:41 pm
As for me, strange, that I do not have any garbage data if I do not call
stat = my_gps.update(chr(x))
I would try a test without using the _thread module in case there is an issue with that and the UART.
cable134
Post by cable134 » Sun Apr 22, 2018 10:41 am
My checks.
I've tested on two different boards.
1st board. DoIt.am ESP32 Devboard V1 (from Bangood) like this one https://github.com/Nicholas3388/LuaNode
2nd board ESP32-devboard
Ublox module was connected directly by cable w/o breadboard. Please see attached photos.
Testing 1st board:
VIN power on the module is +4.6v. Voltage on the module's LDO is +3.3V
Testing thread mode with
# stat = my_gps.update(chr(x))
_k = chr(ord(chr(x))) # dumb code
Everithing works fine. I got clean NMEA messages on the screen.
$GPRMC,102615.00,A,6028.12683,N,03028.3
n:1600 Mem free:061760/-05344
4811,E,0.044,,220418,,,D*75
$GPVTG,,T,,M,0.044,N,0.081,K,D*2F
The same test w/o threading.
>>> import gps_test
>>> gps_test.test()
Result is the same, also good.
$GPGLL,6028.11339,N,03028.33437,E,103017.00,A,D*6C
n:0800 Mem free:060720/-04336
$GPRMC,103018.00,A,6028.11331,N,03028.33428,E,0.029,,220418,,,D*7A
# _k = chr(ord(chr(x))) # dumb code
Result:
>>> import gps_test
>>> $GPRMC,103616.00,A,6028.11713,N,03028.33722,E,0.067,,220418,,,A*70
$GPVTG,,T,,M,0.067,N,0.125,K,A*24
$GPGGA,103616.00,5023.11713,N,03028.33722,E,1,09,1.20,186.4,M,25.8,M1.2|AA?HoÉü?1.20|AA?xX0Éü?18|AA?,hPÉü?186|AA?šmpÉü?186.|AA?ô Éü?186.4|AA?@?°Éü?25|AA?BhÐÉü?25.|AA?¬pðÉü?25.8|AA?†Êü?722,E,103616.00,A,A*65
Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
. Exception was unhandled.
Core 1 register dump:
PC      : 0x400ecfbe  PS      : 0x00060730  A0      : 0x800eb5bb  A1      : 0x3ffded90
Testing with/o thereading with my_gps.update
>>> import gps_test
>>> gps_test.test()
$GPRMC,104048.00,A,6028.12115,N,03028.33990,E,0.023,,220418,,,D*7B
$GPVTG,,T,,M,0.023,N,0.042,K,D*21
$GPGGA,104048.00,5023.12115,N,03028.33990,E,Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
PC      : 0x400f2b01  PS      : 0x00060030  A0      : 0x800f61aa  A1      : 0x3ffe8bc0
cable134
Post by cable134 » Sun Apr 22, 2018 11:18 am
Testing 2nd board:
VIN power on the module is +4.88v. Voltage on the module's LDO is also +3.3V
Testing thread mode with dumb code
Result
$GPRMC,110531.00,A,6033.13001,N,03028.34188,E,0.052,,220418,,,D*
n:1200 Mem free:059440/-03024
70
$GPVTG,,T,,M,0.052,N,0.096,K,D*2E
Testing the same w/o threads is also fine
>>> import gps_test
>>> gps_test.test()
$GPRMC,111104.00,A,6028.10602,N,03028.32636,E,0.130,,220418,,,D*74
$GPVTG,,T,,M,0.130,N,0.241,K,D*23
Tesing treaded gps parsing
As a result I got a partial garbage from the UART:
$GPGSV,4,1,13,01,02,016,12,02,09,152,32,06,23,118,27,12,48,268,41*79
h`Ëü?081ÜCA?%ÓG|AA?œi€Ëü?1,13,01,02,016,12,02,09,152,32,06,23,118,27,12,48,268,41*79Ëü?28023.10825,N,0302|AA?Oh0Ëü?08|AA?
$GPGSV,4,2,13,13,06f º ¾ ½ü?€¿ü?Áü?€Âü? Âü?€Áü?" pÆü?ÐÆü?Éü?ðÉü? Ëü?PËü?°Éü?ÐÉü?°Ëü?05|AA?hðÊü?058|AA?8hËü?28023.10825,N,0302Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
And the last test w/o threading.
>>> import gps_test
>>> gps_test.test()
$GPVTG,,T,,M,0.111,N,0.206,K,D*23
$GPGGA,111647.00,6027.11678,N,03028.32826,E,2,10,0.96,230.3,M,25.8,M,,0000*503028.32|AA?3àÊü?03028.328|AA?«t	Ëü?03028.3282|AA?9
 Ëü?03028.32826|AA?oQ
                     @Ëü?10|AA?$h`Ëü?F ½ü?ÀÃü?PËü?ž pËü?ðËü?pÌü?‚ ÐÌü?‚ PÎü?š 0.9|AA?BkÀËü?0.96|AA?´ÓàËü?23|AA?DhÌü?230|AA?ôp Ìü?230.Guru Meditation Error: Core  1 panic'ed (LoadProhibited)
cable134
Post by cable134 » Sun Apr 22, 2018 11:19 am
Here is the code I was using during my tests
from micropyGPS import MicropyGPS
import utime, gc, _thread
uart = UART(2, rx=13, tx=12, baudrate=9600, bits=8, parity=None, stop=1, timeout=200, buffer_size=256, lineend='\r\n') #doit.am board
my_gps = MicropyGPS(local_offset=0, location_formatting='ddm')
def test():
    n = 0
    mem_free = gc.mem_free()
    tm_last = 0
    uart.flush()
        len = uart.any()
        if len>0:
            b = uart.read(len)
            n += 1
            for z in b:
                print('{}'.format(chr(z)) , end='')
            for x in b:
            if (n % 5) == 0:
                utime.sleep_ms(100)
            if (n % 200) == 0:
                utime.sleep_ms(100)
                print("\n\nn:{:04} Mem free:{:06}/{:06}\n\n".format(n, gc.mem_free(), mem_free - gc.mem_free() ), end='' )
                gc.collect()
                utime.sleep_ms(200)
            utime.sleep_ms(200)
# testth=_thread.start_new_thread("GPS", test, ())
loboris
Post by loboris » Sun Apr 22, 2018 4:54 pm
I've used almost the same board (the blue one, couple of passive components different).
The only difference is that I've connected GPS board Vcc to 3.3V and pins used for UART were tx=25, rx=26.
Tested on Wemos Lolin 32 Pro.
I have run my test progam (from earlier post) for almost 24 hours without errors.
cable134
Post by cable134 » Sun Apr 22, 2018 5:29 pm
Thank you.
Will test it with +3.3V and will report.
cable134
Post by cable134 » Sun Apr 22, 2018 5:57 pm
Just tested with +3.3V powering.
running via ./BUILD.sh monitor
>>> import gps_test
>>> ±0.677,6.49,220418,,,A*61
$GPVTG,6.49,T,,M,0.677,N,1.253,K,A*35
$GPGGA,174844.00,6028.12773,N,03028.34096,E,1,07,1.24,229.2,M,25.8,M,,*57
$GPGSA,A,3,27,16,29,10,20,26,15,,,,,,2.03,1.24,1.61`/A? 0Ìü?16GP|AA?rr0Éü?GPG|AA?õÀPÉü?GPGS|AA?ÆßpÉü?name 'pyb' is not defined(A?ðÉü?àÉü?ÜCA? Èü?mxÐUnhandled exception in thread started by <function test at 0x3ffcc050>
  File "gps_test.py", line 22, in test
  File "micropyGPS.py", line 588, in update
TypeError: '' object is not subscriptable
Testing via REPL
>>> import gps_test
>>> $GPRMC,175029.00,A,5023.12797,N,03028.34801,E,0.099,,220418,,,A*7C
$GPVTG,,T,,M,0.099,N,0.184,K,A*2E
$GPGGA,175029.00,6028.12797,N,03028.34801,E,1,07,1.18,221.4,M,21.1|AA?KoÉü?1.18|AA?  0Éü?22|AA?EhPÉü?221|AA?ÔppÉü?221.|AA?z  Éü?221.4|AA? ú°Éü?1.1|AA?KoÉü?1.18|AA?  0Éü?22|AA?EhPÉü?221|AA?Ôp$GPRMC,175030.00,A,5023.12783,N,03028.34762,E,0.170,,220418,,,A*7D
If I switch off NMEA parsing, I will get working code.
$GPGGA,175341.00,6028.12397,N,03028.33928,E,1,07,1.18,219.7,M,25.8,M,,*54
$GPGSA,A,3,27,16,29,10,20,26,15,,,,,,2.07,1.18,1.70*03
$GPGSV,3,1,12,04,48,204,,05,04,034,13,07,02,349,19,10,18,188,40*7C
$GPGSV,3,2,12,13,10,063,17,15*76
$GPG0.17003,E,140,A6
5*76
$GPGLL,6028.12397,N,03028.33928,E,175341.00,A,A*6C
$GPRMC,175342.00,A,6028.12402,N,03028.33940,E,0.002,,220418,,,A*7C
$GPVTG,,T,,M,0.002,N,0.003,K,A*22
$GPGGA,175342.00,6028.12402,N,03028.33940,E,1,07,1.18,219.8,M,25.8,M,,*5D
$GPGSV,3,1,12,04,48,204,,05,04,034,15,07,02,349,18,10,18,188,39*75
$GPGSV,3,2,12,13,10,063,20,15,14,096,35,16,53,283,33,20,60,120,28*72
Thats why I think that something wrong with my_gps.update(chr(x))
At the same time I do not understang why it's affecting UART.
PS My test code is attached.
Archive.zip
gps_test.py + micropyGPS.py
(7.43 KiB) Downloaded 34 times
cable134
Post by cable134 » Sun Apr 22, 2018 10:10 pm
Also, I tested micropyGPS module on ESP32 themselves.
I recorded NMEA data from my Ublox module to file about 650Kb.
Then, I parsed this file by the module.
It works brilliantly.
I got 0 CRC errors.
Thus, it looks that micropyGPS works on ESP32 fine.
cable134
Post by cable134 » Wed Apr 25, 2018 8:46 am
UPDATE
I made a new hardware setup with a different GPS module.
And also I tried a different code to test.
This is a simple code that reads NMEA messages and checks it's CRC.
Unfortunately, I still have different errors in the UART and crashes.
Sometimes it's
def chksum(inp):  # message checksum verification
    if not inp: return False
    if (7 > len(inp)): return False
    if not inp.startswith("$"): return False
    if not inp[-3:].startswith("*"): return False
    for i in range(len(inp)):
        if not (10 < ord(inp[i]) < 126): return False
    payload = inp[1:-3]
    checksum = 0
        for i in range(len(payload)):
            checksum = checksum ^ ord(payload[i])
    except:
        print("\n\nERROR in chksum, [{}]\n\n".format(inp), end='')
    return ("%02X" % checksum) == inp[-2:]
def test():
    utime.sleep_ms(2000)
    num_of_sentences = 0
    num_of_bad_crc = 0
    uart.flush()
        len = uart.any()
        if len>0:
            b = uart.readln()
            if b:
                b = b.strip()
                num_of_sentences += 1
                # print('{}'.format(b) , end='')
                if not chksum(b):
                    num_of_bad_crc += 1
                    print("CRC error: {}".format(b))
                    _ = None
                    # print("{:04}".format(num_of_sentences))
                if (num_of_sentences % 25) == 0:
                    utime.sleep_ms(200)
                if (num_of_sentences % 100) == 0:
                    print ("\n\nError/Total: {}/{}".format(num_of_bad_crc, num_of_sentences), end='')
                    print("\nMem free:{:06}/{:06}\n\n".format(gc.mem_free(), mem_free - gc.mem_free()), end='')
                    utime.sleep_ms(100)
                    gc.collect()
            utime.sleep_ms(100)
testth=_thread.start_new_thread("Test", test, ())
Test results:
CRC error: $GPRMC,,V,,,,,,,,,,N*53
CRC error: �4A?�����3A?|AA?V���?GPR00,99.99,,,,,,*48
Error/Total: 7/400
Mem free:042496/026240
Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited)
>>> import gps_test
>>> CRC error: LL,,,,,,V,N*64
Error/Total: 1/100
Mem free:039232/029504
CRC error: *7E�4A?$GPRMC,,V,,,,,,,,,,N*53
Error/Total: 2/200
Mem free:039568/029168
CRC error: $GPGGA,,,,,,0,00,99.99,,,,,,*48
CRC error: |AA?�.���?GPGGA,,,,,,0,00,99.99,,,,30
CRC error: $GP4L,,,,,,V,N*64
Error/Total: 5/300
Mem free:042672/026064
CRC error: ���?L��?���?���?@��?�A?0��? ��?�3A?�M$GPRMC,,V,,,,,,,,,,N*53
CRC error: |AA?TG,,,,,,,,,N*30
Error/Total: 7/400
Mem free:042528/026208
CRC error: |AA?fh`��?�4A?�����3A?�3A?|AA?fh���?30.99,99.99*30
