micropyGPS crashes my ESP32
Re: micropyGPS crashes my ESP32
Also make sure that ground is connected between the GPS module and the microcontroller.
I would try a test without using the _thread module in case there is an issue with that and the UART.cable134 wrote: ↑Sat Apr 21, 2018 9:41 pmAs for me, strange, that I do not have any garbage data if I do not callCode: Select all
stat = my_gps.update(chr(x))
My checks.
I've tested on two different boards.
1st board. DoIt.am ESP32 Devboard V1 (from Bangood) like this one https://github.com/Nicholas3388/LuaNode
2nd board ESP32-devboard
Ublox module was connected directly by cable w/o breadboard. Please see attached photos.
Testing 1st board:
VIN power on the module is +4.6v. Voltage on the module's LDO is +3.3V
Testing thread mode with
Everithing works fine. I got clean NMEA messages on the screen.
The same test w/o threading.
Result is the same, also good.
Result:
Testing with/o thereading with my_gps.update
Testing 1st board:
# stat = my_gps.update(chr(x))
_k = chr(ord(chr(x))) # dumb code
$GPRMC,102615.00,A,6028.12683,N,03028.3
n:1600 Mem free:061760/-05344
4811,E,0.044,,220418,,,D*75
$GPVTG,,T,,M,0.044,N,0.081,K,D*2F
>>> import gps_test
>>> gps_test.test()
$GPGLL,6028.11339,N,03028.33437,E,103017.00,A,D*6C
n:0800 Mem free:060720/-04336
$GPRMC,103018.00,A,6028.11331,N,03028.33428,E,0.029,,220418,,,D*7A
# _k = chr(ord(chr(x))) # dumb code
>>> import gps_test
>>> $GPRMC,103616.00,A,6028.11713,N,03028.33722,E,0.067,,220418,,,A*70
$GPVTG,,T,,M,0.067,N,0.125,K,A*24
$GPGGA,103616.00,5023.11713,N,03028.33722,E,1,09,1.20,186.4,M,25.8,M1.2|AA?HoÉü?1.20|AA?xX0Éü?18|AA?,hPÉü?186|AA?mpÉü?186.|AA?ô Éü?186.4|AA?@?°Éü?25|AA?BhÐÉü?25.|AA?¬pðÉü?25.8|AA?Êü?722,E,103616.00,A,A*65
Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
. Exception was unhandled.
Core 1 register dump:
PC : 0x400ecfbe PS : 0x00060730 A0 : 0x800eb5bb A1 : 0x3ffded90
>>> import gps_test
>>> gps_test.test()
$GPRMC,104048.00,A,6028.12115,N,03028.33990,E,0.023,,220418,,,D*7B
$GPVTG,,T,,M,0.023,N,0.042,K,D*21
$GPGGA,104048.00,5023.12115,N,03028.33990,E,Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
PC : 0x400f2b01 PS : 0x00060030 A0 : 0x800f61aa A1 : 0x3ffe8bc0
- IMG_5726.jpg (157.44 KiB) Viewed 6884 times
- IMG_5725.jpg (137.06 KiB) Viewed 6884 times
Testing 2nd board:
VIN power on the module is +4.88v. Voltage on the module's LDO is also +3.3V
Testing thread mode with dumb code
Result
Testing the same w/o threads is also fine
Tesing treaded gps parsing
As a result I got a partial garbage from the UART:
And the last test w/o threading.
$GPRMC,110531.00,A,6033.13001,N,03028.34188,E,0.052,,220418,,,D*
n:1200 Mem free:059440/-03024
70
$GPVTG,,T,,M,0.052,N,0.096,K,D*2E
>>> import gps_test
>>> gps_test.test()
$GPRMC,111104.00,A,6028.10602,N,03028.32636,E,0.130,,220418,,,D*74
$GPVTG,,T,,M,0.130,N,0.241,K,D*23
$GPGSV,4,1,13,01,02,016,12,02,09,152,32,06,23,118,27,12,48,268,41*79
h`Ëü?081ÜCA?%ÓG|AA?iËü?1,13,01,02,016,12,02,09,152,32,06,23,118,27,12,48,268,41*79Ëü?28023.10825,N,0302|AA?Oh0Ëü?08|AA?
$GPGSV,4,2,13,13,06f º ¾ ½ü?¿ü?Áü?Âü? Âü?Áü?" pÆü?ÐÆü?Éü?ðÉü? Ëü?PËü?°Éü?ÐÉü?°Ëü?05|AA?hðÊü?058|AA?8hËü?28023.10825,N,0302Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
>>> import gps_test
>>> gps_test.test()
$GPVTG,,T,,M,0.111,N,0.206,K,D*23
$GPGGA,111647.00,6027.11678,N,03028.32826,E,2,10,0.96,230.3,M,25.8,M,,0000*503028.32|AA?3àÊü?03028.328|AA?«t Ëü?03028.3282|AA?9
Ëü?03028.32826|AA?oQ
@Ëü?10|AA?$h`Ëü?F ½ü?ÀÃü?PËü? pËü?ðËü?pÌü? ÐÌü? PÎü? 0.9|AA?BkÀËü?0.96|AA?´ÓàËü?23|AA?DhÌü?230|AA?ôp Ìü?230.Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
- IMG_5727.jpg (176.92 KiB) Viewed 6883 times
Here is the code I was using during my tests
from micropyGPS import MicropyGPS
import utime, gc, _thread
uart = UART(2, rx=13, tx=12, baudrate=9600, bits=8, parity=None, stop=1, timeout=200, buffer_size=256, lineend='\r\n') #doit.am board
my_gps = MicropyGPS(local_offset=0, location_formatting='ddm')
def test():
n = 0
mem_free = gc.mem_free()
tm_last = 0
uart.flush()
len = uart.any()
if len>0:
b = uart.read(len)
n += 1
for z in b:
print('{}'.format(chr(z)) , end='')
for x in b:
if (n % 5) == 0:
utime.sleep_ms(100)
if (n % 200) == 0:
utime.sleep_ms(100)
print("\n\nn:{:04} Mem free:{:06}/{:06}\n\n".format(n, gc.mem_free(), mem_free - gc.mem_free() ), end='' )
gc.collect()
utime.sleep_ms(200)
utime.sleep_ms(200)
# testth=_thread.start_new_thread("GPS", test, ())
I've used almost the same board (the blue one, couple of passive components different).
The only difference is that I've connected GPS board Vcc to 3.3V and pins used for UART were tx=25, rx=26.
Tested on Wemos Lolin 32 Pro.
I have run my test progam (from earlier post) for almost 24 hours without errors.
Thank you.loboris wrote: ↑Sun Apr 22, 2018 4:54 pmI've used almost the same board (the blue one, couple of passive components different).
Will test it with +3.3V and will report.
Just tested with +3.3V powering.
running via ./BUILD.sh monitor
Testing via REPL
If I switch off NMEA parsing, I will get working code.
Thats why I think that something wrong with my_gps.update(chr(x))
At the same time I do not understang why it's affecting UART.
PS My test code is attached.
>>> import gps_test
>>> ±0.677,6.49,220418,,,A*61
$GPVTG,6.49,T,,M,0.677,N,1.253,K,A*35
$GPGGA,174844.00,6028.12773,N,03028.34096,E,1,07,1.24,229.2,M,25.8,M,,*57
$GPGSA,A,3,27,16,29,10,20,26,15,,,,,,2.03,1.24,1.61`/A? 0Ìü?16GP|AA?rr0Éü?GPG|AA?õÀPÉü?GPGS|AA?ÆßpÉü?name 'pyb' is not defined(A?ðÉü?àÉü?ÜCA? Èü?mxÐUnhandled exception in thread started by <function test at 0x3ffcc050>
File "gps_test.py", line 22, in test
File "micropyGPS.py", line 588, in update
TypeError: '' object is not subscriptable
>>> import gps_test
>>> $GPRMC,175029.00,A,5023.12797,N,03028.34801,E,0.099,,220418,,,A*7C
$GPVTG,,T,,M,0.099,N,0.184,K,A*2E
$GPGGA,175029.00,6028.12797,N,03028.34801,E,1,07,1.18,221.4,M,21.1|AA?KoÉü?1.18|AA? 0Éü?22|AA?EhPÉü?221|AA?ÔppÉü?221.|AA?z Éü?221.4|AA? ú°Éü?1.1|AA?KoÉü?1.18|AA? 0Éü?22|AA?EhPÉü?221|AA?Ôp$GPRMC,175030.00,A,5023.12783,N,03028.34762,E,0.170,,220418,,,A*7D
$GPGGA,175341.00,6028.12397,N,03028.33928,E,1,07,1.18,219.7,M,25.8,M,,*54
$GPGSA,A,3,27,16,29,10,20,26,15,,,,,,2.07,1.18,1.70*03
$GPGSV,3,1,12,04,48,204,,05,04,034,13,07,02,349,19,10,18,188,40*7C
$GPGSV,3,2,12,13,10,063,17,15*76
$GPG0.17003,E,140,A6
5*76
$GPGLL,6028.12397,N,03028.33928,E,175341.00,A,A*6C
$GPRMC,175342.00,A,6028.12402,N,03028.33940,E,0.002,,220418,,,A*7C
$GPVTG,,T,,M,0.002,N,0.003,K,A*22
$GPGGA,175342.00,6028.12402,N,03028.33940,E,1,07,1.18,219.8,M,25.8,M,,*5D
$GPGSV,3,1,12,04,48,204,,05,04,034,15,07,02,349,18,10,18,188,39*75
$GPGSV,3,2,12,13,10,063,20,15,14,096,35,16,53,283,33,20,60,120,28*72
- Archive.zip
- gps_test.py + micropyGPS.py
- (7.43 KiB) Downloaded 232 times
Also, I tested micropyGPS module on ESP32 themselves.
I recorded NMEA data from my Ublox module to file about 650Kb.
Then, I parsed this file by the module.
It works brilliantly.
I got 0 CRC errors.
Thus, it looks that micropyGPS works on ESP32 fine.
I got 0 CRC errors.
UPDATE
I made a new hardware setup with a different GPS module.
And also I tried a different code to test.
This is a simple code that reads NMEA messages and checks it's CRC.
Unfortunately, I still have different errors in the UART and crashes.
Sometimes it's
Test results:
Sometimes it's
def chksum(inp): # message checksum verification
if not inp: return False
if (7 > len(inp)): return False
if not inp.startswith("$"): return False
if not inp[-3:].startswith("*"): return False
for i in range(len(inp)):
if not (10 < ord(inp[i]) < 126): return False
payload = inp[1:-3]
checksum = 0
for i in range(len(payload)):
checksum = checksum ^ ord(payload[i])
except:
print("\n\nERROR in chksum, [{}]\n\n".format(inp), end='')
return ("%02X" % checksum) == inp[-2:]
def test():
utime.sleep_ms(2000)
num_of_sentences = 0
num_of_bad_crc = 0
uart.flush()
len = uart.any()
if len>0:
b = uart.readln()
if b:
b = b.strip()
num_of_sentences += 1
# print('{}'.format(b) , end='')
if not chksum(b):
num_of_bad_crc += 1
print("CRC error: {}".format(b))
_ = None
# print("{:04}".format(num_of_sentences))
if (num_of_sentences % 25) == 0:
utime.sleep_ms(200)
if (num_of_sentences % 100) == 0:
print ("\n\nError/Total: {}/{}".format(num_of_bad_crc, num_of_sentences), end='')
print("\nMem free:{:06}/{:06}\n\n".format(gc.mem_free(), mem_free - gc.mem_free()), end='')
utime.sleep_ms(100)
gc.collect()
utime.sleep_ms(100)
testth=_thread.start_new_thread("Test", test, ())
CRC error: $GPRMC,,V,,,,,,,,,,N*53
CRC error: �4A?�����3A?|AA?V���?GPR00,99.99,,,,,,*48
Error/Total: 7/400
Mem free:042496/026240
Guru Meditation Error: Core 1 panic'ed (InstrFetchProhibited)
>>> import gps_test
>>> CRC error: LL,,,,,,V,N*64
Error/Total: 1/100
Mem free:039232/029504
CRC error: *7E�4A?$GPRMC,,V,,,,,,,,,,N*53
Error/Total: 2/200
Mem free:039568/029168
CRC error: $GPGGA,,,,,,0,00,99.99,,,,,,*48
CRC error: |AA?�.���?GPGGA,,,,,,0,00,99.99,,,,30
CRC error: $GP4L,,,,,,V,N*64
Error/Total: 5/300
Mem free:042672/026064
CRC error: ���?L��?���?���?@��?�A?0��? ��?�3A?�M$GPRMC,,V,,,,,,,,,,N*53
CRC error: |AA?TG,,,,,,,,,N*30
Error/Total: 7/400
Mem free:042528/026208
CRC error: |AA?fh`��?�4A?�����3A?�3A?|AA?fh���?30.99,99.99*30
- IMG_5748.jpg (232.41 KiB) Viewed 6838 times
