Hi I'm trying to compile Micropython for development board OGTT
I have the following error:
/home/vagrant/esp-idf//components/bootloader_support/include/esp_flash_partitions.h:25:36: error: 'CONFIG_PARTITION_TABLE_OFFSET' undeclared (first use in this function)
makefile:
ESPIDF = $(HOME)/esp-idf/
PORT = /dev/ttyUSB0
FLASH_MODE = dio
FLASH_SIZE = 4MB
#CROSS_COMPILE = xtensa-esp32-elf-
include Makefile
xtensa-esp32-elf-gcc -v
Using built-in specs.
COLLECT_GCC=xtensa-esp32-elf-gcc
COLLECT_LTO_WRAPPER=/home/vagrant/xtensa-esp32-elf/bin/../libexec/gcc/xtensa-esp32-elf/5.2.0/lto-wrapper
Target: xtensa-esp32-elf
Configured with: /home/ivan/e/crosstool-NG/.build/src/gcc-5.2.0/configure --build=x86_64-build_pc-linux-gnu
Thread model: single
gcc version 5.2.0 (crosstool-NG crosstool-ng-1.22.0-61-gab8375a)
Thank you, have a nice day
Problem compiling micropython for TTGO (ESP32 + Lora)
Re: Problem compiling micropython for TTGO (ESP32 + Lora)
CC /home/vagrant/esp-idf//components/bootloader_support/src/bootloader_clock.c
CC /home/vagrant/esp-idf//components/bootloader_support/src/bootloader_common.c
CC /home/vagrant/esp-idf//components/bootloader_support/src/bootloader_flash.c
CC /home/vagrant/esp-idf//components/bootloader_support/src/bootloader_init.c
In file included from /home/vagrant/esp-idf//components/bootloader_support/src/bootloader_common.c:26:0:
/home/vagrant/esp-idf//components/bootloader_support/src/bootloader_common.c: In function 'bootloader_common_erase_part_type_data':
#define ESP_PARTITION_TABLE_OFFSET CONFIG_PARTITION_TABLE_OFFSET /* Offset of partition table. Backwards-compatible name.*/
/home/vagrant/esp-idf//components/bootloader_support/src/bootloader_common.c:115:34: note: in expansion of macro 'ESP_PARTITION_TABLE_OFFSET'
partitions = bootloader_mmap(ESP_PARTITION_TABLE_OFFSET, ESP_PARTITION_TABLE_MAX_LEN);
/home/vagrant/esp-idf//components/bootloader_support/include/esp_flash_partitions.h:25:36: note: each undeclared identifier is reported only once for each function it appears in
make: *** [build/bootloader//home/vagrant/esp-idf//components/bootloader_support/src/bootloader_common.o] Error 1
make: *** Waiting for unfinished jobs....
@fandres I also have a TTGO (specifically a TTGO TM 2.4 inch) right now in the mean time I'm using binaries from https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo which seems to be working properly.
The only bad thing is that documentation from TTGO is not as they said, I have encounter some issues on their documentation but no answer from them yet.
I encourage you to use those binaries from @loboris.
P.D I know this does not solve your problem but it could at least help you out to try micro python on the TTGO board.
Hello Friend,
Download the .bin from the micropython website (for ESP32), it works. although my idea is to compile MicroPython with the driver of https://github.com/rcludwick/Lora_drive ... on_on_ttgo
I'll try with what you say, Thank you
The problem is given by not using the correct version of the ESP IDF.
When you run make from within the ports/esp32 directory you might get a message like this:
The line that says "Supported hit hash" is the correct hash to use. and following the rest of the instructions on the ports/esp32/README.md file, you should get a build.
536 >make
** WARNING **
The git hash of ESP IDF does not match the supported version
The build may complete and the firmware may work but it is not guaranteed
ESP IDF path: /home/dhylands/esp/esp-idf
Current git hash: a3c43251b4b37bc3ec105a10f2e1413b14420da3
Supported git hash: 9a55b42f0841b3d38a61089b1dda4bf28135decd
CC /home/dhylands/esp/esp-idf/components/bootloader_support/src/bootloader_common.c
In file included from /home/dhylands/esp/esp-idf/components/bootloader_support/src/bootloader_common.c:26:0:
/home/dhylands/esp/esp-idf/components/bootloader_support/src/bootloader_common.c: In function 'bootloader_common_erase_part_type_data':
/home/dhylands/esp/esp-idf/components/bootloader_support/include/esp_flash_partitions.h:25:36: error: 'CONFIG_PARTITION_TABLE_OFFSET' undeclared (first use in this function)
git checkout 9a55b42f0841b3d38a61089b1dda4bf28135decd
git submodule update --init --recursive
