Installing libraries on ESP32
guyd
Re: Installing libraries on ESP32
Post by guyd » Fri Jul 27, 2018 12:19 pm
pythoncoder wrote:
Tue Jul 24, 2018 5:59 am
You should be able to install it using upip as described. What happens when you try?
Alternatively just copy datetime.py from micropython-lib to the ESP32: this should work as it's a simple library comprising just that one file. I have a clone of micropython-lib on my local hardware for such purposes.
Copied to root directory of pyboard, and got this message;
>>> import datetime
MemoryError: memory allocation failed, allocating 136 bytes
Post by pythoncoder » Sat Jul 28, 2018 6:52 am
I hadn't spotted how big datetime.py is. Looking at the code it's the CPython 3.5 version, lightly modified. There is a case for a "micro" subset to be written.
If it's throwing a memory error on import immediately after a boot, it's too big for the target's RAM. Your best hope is to cross-compile it and copy the datetime.mpy to the target. Failing that you'll need to use frozen bytecode. Or use an ESP32 with SPIRAM and the Loboris port.
I suppose a last resort is to roll your own alternative by stripping out any functionality you don't need.
guyd
Post by guyd » Thu Aug 02, 2018 11:19 am
I try again to use datetime.py library ( after reflashing MicroPython again ).
As you suggested before - just copied datetime.py to ESP32 main directory.
additional services loaded: 1) wifi connection, 2)update RTC, both went successfully.
now again when I try to import datetime- I get a memery allocation err, as show before.
Can you explain what do I do wrong ?
Guy
SpotlightKid
Post by SpotlightKid » Thu Aug 02, 2018 12:28 pm
Nothing. pythoncoder already explained to you what is going on in his last reply in the second paragraph.
Please read this for further explanation: http://docs.micropython.org/en/latest/e ... ained.html
Post by Roberthh » Thu Aug 02, 2018 1:09 pm
@pythoncoder:
The micropython.org port also supports SPIRAM. https://github.com/micropython/micropyt ... 092ee354b0
zelezni
Post by zelezni » Sun Oct 18, 2020 4:18 pm
This is rather old post, but hopefully my answer will prevent someone to spend "hours" looking for a solution (as I just did):
I am on Windows. In command prompt first navigate to a folder, where you've installed rshell. Activate it and enter repl. Then:
import upip
upip.install('<desired_package_name>')
Example:
upip.install('urllib.parse')
So, you are installing module directly on the board. Note that board needs to be connected to the internet for this to work.
Happy coding!
MrR^2
Post by MrR^2 » Thu Oct 22, 2020 2:32 am
Another way to get an easy repl on Windows is to use UPycraft.
~MrR^2
