rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4596
load:0x40078000,len:0
load:0x40078000,len:12768
entry 0x4007ad68
I (387) cpu_start: Pro cpu up.
I (387) cpu_start: Single core mode
I (388) heap_init: Initializing. RAM available for dynamic allocation:
I (391) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (397) heap_init: At 3FFC57D0 len 0001A830 (106 KiB): DRAM
I (403) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (410) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (416) heap_init: At 40091B28 len 0000E4D8 (57 KiB): IRAM
I (422) cpu_start: Pro cpu start user code
I (216) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.4-403-g81e320aec on 2018-07-21; ESP32 module with ESP32
>>> import network
>>> sta=network.WLAN(network.STA_IF)
I (75895) wifi: wifi driver task: 3ffcb834, prio:23, stack:4096, core=0
I (75895) wifi: wifi firmware version: ac8d7b4
I (75895) wifi: config NVS flash: enabled
I (75895) wifi: config nano formating: disabled
I (75905) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (75915) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (75925) wifi: Init dynamic tx buffer num: 32
I (75925) wifi: Init data frame dynamic rx buffer num: 64
I (75935) wifi: Init management frame dynamic rx buffer num: 64
I (75935) wifi: Init static rx buffer size: 1600
I (75945) wifi: Init static rx buffer num: 10
I (75945) wifi: Init dynamic rx buffer num: 0
>>> sta.active(True)
I (86585) phy: phy_version: 3910, c0c45a3, May 21 2018, 18:07:06, 0, 0
I (86585) wifi: mode : sta (30:ae:a4:0d:b0:20)
I (86585) wifi: STA_START
True
>>> sta.connect("xxxx","xxxx")
>>> I (121245) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (121815) wifi: state: init -> auth (b0)
I (121815) wifi: state: auth -> assoc (0)
I (121815) wifi: state: assoc -> run (10)
I (121845) wifi: connected with xxxx, channel 1
I (121845) wifi: pm start, type: 1
I (121845) network: CONNECTED
I (123605) event: sta ip: 192.168.1.24, mask: 255.255.255.0, gw: 192.168.1.1
I (123605) network: GOT_IP
>>> import usocket
I (257785) modsocket: Initializing
>>> sockaddr=usocket.getaddrinfo('www.micropython.org',80)
>>> sock=usocket.socket(usocket.AF_INET,usocket.SOCK_STREAM)
>>> sock.connect(sockaddr)
CORRUPT HEAP: multi_heap.c:165 detected at 0x3ffe641c
abort() was called at PC 0x4008ec9b on core 0
Backtrace: 0x4008f49b:0x3ffb6e30 0x4008f4c7:0x3ffb6e50 0x4008ec9b:0x3ffb6e70 0x4008ef40:0x3ffb6e90 0x4008f09d:0x3ffb6eb0 0x40083812:0x3ffb6ed0 0x400812bd:0x3ffb6ef0 0x4000bec7:0x3ffb6f10 0x4010829f:0x3ffb6f30 0x400f220a:0x3ffb6f50 0x400df9b6:0x3ffb6f80 0x400dbd61:0x3ffb6fa0 0x400dbdc9:0x3ffb6fc0 0x400e9015:0x3ffb6fe0 0x400dfad8:0x3ffb7080 0x400dbd61:0x3ffb70f0 0x400dbd8e:0x3ffb7110 0x400f8db6:0x3ffb7130 0x400f8ff4:0x3ffb71d0 0x400efde4:0x3ffb7210
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x4007ad68
