Rshell error raspberry pi0w to esp32
alien1983
Post by alien1983 » Fri Sep 07, 2018 5:25 pm
Connect by Screen to esp32 micropython is ok (raspberry pi0W =>> esp32 via usb )
But by rshell it not work:/
root@raspberrypi:/home/pi/esp# rshell --buffer-size=30 -p /dev/ttyU
SB0
File "/usr/local/bin/rshell", line 9, in <module>
load_entry_point('rshell==0.0.14', 'console_scripts', 'rshell')()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 356, in loa
d_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2476, in lo
ad_entry_point
return ep.load()
File "/usr/lib/python3/dist-packages/pkg_resources.py", line 2190, in lo
ad
['__name__'])
File "/usr/local/lib/python3.4/dist-packages/rshell/command_line.py", li
ne 1, in <module>
import rshell.main
File "/usr/local/lib/python3.4/dist-packages/rshell/main.py", line 508
wrapper.extra_funcs = [*funcs]
SyntaxError: can use starred expression only as
assignment target
Re: Rshell error raspberry pi0w to esp32
Post by dhylands » Sat Sep 08, 2018 3:29 am
You can't use screen and rshell at the same time to connect to a MicroPython board. You need to quite out of screen and then use rshell,
alien1983
Post by alien1983 » Sat Sep 08, 2018 5:58 am
there is the same error.
Screen have no connection to esp.
Post by pythoncoder » Sat Sep 08, 2018 4:54 pm
assignment target
@dhylands Dave, that line of code looks suspect to me. Should it read
    wrapper.extra_funcs = list(funcs)
Post by dhylands » Sat Sep 08, 2018 6:33 pm
assignment target
I created this little test program:
#!/usr/bin/env python3
import inspect
def extra_funcs(*funcs):
    """Decorator which adds extra functions to be downloaded to the pyboard."""
    def extra_funcs_decorator(real_func):
        def wrapper(*args, **kwargs):
          return real_func(*args, **kwargs)
        wrapper.source = inspect.getsource(real_func)
        wrapper.name = real_func.__name__
        return wrapper
    return extra_funcs_decorator
def foo1():
    print('foo1')
def foo2():
    print('foo2')
@extra_funcs(foo1, foo2)
def bar():
    print('bar')
def test_func(func):
    if hasattr(func, 'extra_funcs'):
        print('test_func: extra_funcs =', func.extra_funcs)
        print('test_func: no extra_funcs')
test_func(bar)
and it seems to work either way for me (using python 3.6.5) and my Raspberry Pi (running Python 3.5.3)
I did a bit of searching and it appears that prior to 3.5.0 this syntax wasn't allowed. And using the `list(funcs)` variant works properly under python2, so I'll go ahead and change it.
Post by pythoncoder » Sun Sep 09, 2018 4:03 am
That syntax must be new for V3.5, as it fails here under V3.4.3.
alien1983
Post by alien1983 » Sun Sep 09, 2018 2:27 pm
With python 3.4 & 3.7 not work.
The best idea is reinstall raspberry pi ?
Post by dhylands » Mon Sep 10, 2018 2:48 am
The quickest way would be to edit the file with the error and change the [*funcs] to list(funcs) i.e. Change:
to be:
The file to edit was mentioned in the error: /usr/local/lib/python3.4/dist-packages/rshell/main.py line 508
alien1983
Post by alien1983 » Mon Sep 10, 2018 3:46 pm
Thx
Post by dhylands » Mon Sep 10, 2018 9:39 pm
I just created and released version 0.0.15 of rshell which should address the problem.
