Barebones ESP32-WROVER
I see that Mouser has the ESP32-WROVER for around $4. Assuming you don't need USB, would it be correct to conclude that the only other components required are a 10K resistor to pull up the enable pin and a couple of decoupling caps?
Re: Barebones ESP32-WROVER
U will also need a power regulator (LDO)
Any recommendations for efficient 5V to 3.3V (preferably surface mount)?
Has anyone determined the minimum current requirements? I know the Wi-Fi can be relatively demanding.
The Wrover datasheet has a recommended peripheral circuits see below
http://www.ti.com/product/tps63000/description buck/boost converter from TI that is designed for running efficiently a 3.3v MCUs off a 1 cell Lipo with input range of 1.8v -0 5.5v. TI do also make some even smaller BGA packages as well but they were getting beyond my soldering.
The ESP32 datasheet has the radio power consumption listed too see below
I did plan to make a low power ESP32 using this Re: Barebones ESP32-WROVER
Thanks that's very helpful.
The current specs are typical, but it has been my observations that there is a current spike when the radio is turned on. Often the spike is enough to brown out when using an inadequate power supply.
Yes do note the recommended caps on the wrover peripheral schematics. I have used boards where they have reduced the caps and had troubles with unstable behavior, this is the reason that I started to build my own boards.
I have just mainly used the AMS1117 LDO as it is a tank that can supply way more than anything that I need but others haven't liked it due to high quendesint current during deep sleep mode.
Are you using ESP32-WROVER or ESP32-WROVER-B?
Is the B version the same except more PSRAM and smaller chip size?
I am using the original Wrover not sure about what's different with the Wrover-b
edit : it looks like the Wrover-B has 8MB psRAM instead of 4MB psRAM not sure what other differences there is
edit : it also uses the new version of the ESP32 chip ESP32‑D0WD
