I am using ESP32 WROVER module.
Can I set input pull-mode as follows, when I use a Pin as the input mode for ESP32 WROVER module?
1) p = Pin(Pin_number, Pin.IN) # for No Pull
2) p = Pin(Pin_number, Pin.IN, Pin.PULL_UP)
3) p = Pin(Pin_number, Pin.IN, Pin.PULL_DOWN)
When I refer to ESP8266 GPIO Pin document(https://docs.micropython.org/en/latest/ ... /pins.html), I can't find PULL_DOWN mode.
Please let me know the answer.
Pin input pull-mode of ESP32 WROVER module
Re: Pin input pull-mode of ESP32 WROVER module
You should refer to the full reference documentation, not only to the tutorial:
https://docs.micropython.org/en/latest/ ... e.Pin.html
