Connecting to doit.am boards fails
Re: Connecting to doit.am boards fails
Post by pythoncoder » Wed Oct 24, 2018 5:52 am
I invoke rshell for ESPx boards with this Bash alias:
alias rsusb='rshell -p /dev/ttyUSB0 --editor nano --buffer-size=30 -a'
You can omit the '--editor nano' part if you don't want to edit files directly on the target. The -a flag avoids an issue if you copy binary files to ESPx boards.
That takes you to the rshell prompt where you can perform file copies or syncs. Then issue repl to get to the REPL.
If you issue a command at the Bash prompt like
rsusb cp myfile.py /pyboard
rshell will copy the file to the target and return to the Bash prompt.
