Non blocking console/keyboard input
uCTRL
Post by uCTRL » Fri Nov 09, 2018 7:46 am
For ESP32 Uart console/keyboard input.
Basically, need advice for non-blocking keyboard input from Uart console port, as scanned 1 character at the time.
input() and sys.stdin are blocking.
Re: Non blocking console/keyboard input
Post by pythoncoder » Fri Nov 09, 2018 9:08 am
In general UARTS can operate in a non-blocking mode by using uasyncio StreamReader and StreamWriter objects. See the tutorial in this repo.
uCTRL
Post by uCTRL » Fri Nov 09, 2018 9:39 am
Thanks Peter
I would also like to know if there is a simpler system call to access existing OS keyboard scan.
Post by pythoncoder » Sat Nov 10, 2018 10:47 am
In general (and in particular on the ESP32) MicroPython runs on bare metal. There is no OS. If you want to connect a serial keyboard to an ESP32 you will need to interpret the data yourself. Unless someone has already posted code to do this.
