Page 1 of 3
optimizing uasyncio performance
Posted: Tue Dec 04, 2018 7:06 pm
by Mike Teachman
I'm hoping a uasyncio expert can comment on performance challenges I'm facing. I'm not a uasyncio expert and suspect that I am using the library incorrectly.
Background
I am using the usayncio library in a uPy project to manage operation of sensors, a display, and an I2S microphone. It was all coming together until I starting seeing performance issues with the I2S microphone - gaps were appearing in the audio sample stream.
The I2S microphone code runs in a coro loop that looks like this:
a) read 2048 bytes of audio samples from the microphone using I2S
b) call await asyncio.sleep(0) to yield
c) prune out unused bytes, 2048->512 bytes
d) call await asyncio.sleep(0) to yield
e) write 512 bytes to WAV file on a SD Card
f) call await asyncio.sleep(0) to yield
g) loop back to a)
The ambition is a gap-less audio stream recorded to a WAV file. It works, except when I implement with uasyncio ...
Here is the file being discussed:
https://github.com/MikeTeachman/micropy ... etsense.py
in this repo:
https://github.com/MikeTeachman/micropy ... reet-sense
Performance challenges with uasyncio
1. calls to await asyncio.sleep(0) in this application consistency take > 6ms to run, sometimes 10ms -- this adds delays into the microphone read-write loop, putting constraints on the sample rate that can be used.
https://github.com/MikeTeachman/micropy ... se.py#L283
2. frequent garbage collection
Environment:
- I am using the ESP32 LoBo build, with customization to support I2S
- board is Lolin D32 Pro (4MB PSRAM)
Here is a testcase illustrating both issues. You will see the call to await asyncio.sleep(0) taking > 3ms to return and rapid "consumption" of the uPy heap.
Testcase
import utime
import uasyncio as asyncio
import asyn
import gc
async def idle():
        print("  -- idle --")
        await asyncio.sleep(1)
        utime.sleep_us(1) # workaround for watchdog trigger issue in LoBo port
        print(gc.mem_free())
async def task1(b):
        print("  -- task1 --")
        await b
        await asyncio.sleep(2)
async def task2(b):
    t0 = 0
    t1 = 0
        print("  -- task2 --")
        t0 = utime.ticks_us()
        t1 = utime.ticks_us()
        print("asyncio.sleep(0) = {} us".format(t1-t0))
        await b
        await asyncio.sleep(3)
barrier = asyn.Barrier(2)
loop.create_task(idle())
loop.create_task(task1(barrier))
loop.create_task(task2(barrier))
loop.run_forever()
testcase output:
  -- idle --
  -- task1 --
  -- task2 --
asyncio.sleep(0) = 2464 us
472800
  -- idle --
472400
  -- idle --
  -- task1 --
  -- task2 --
asyncio.sleep(0) = 3149 us
417184
  -- idle --
416784
  -- idle --
  -- task1 --
414976
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3083 us
361264
  -- idle --
360864
  -- idle --
  -- task1 --
357808
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3087 us
305248
  -- idle --
304848
  -- idle --
  -- task1 --
300448
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3052 us
249040
  -- idle --
248640
  -- idle --
  -- task1 --
242992
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3112 us
193312
  -- idle --
192912
  -- idle --
  -- task1 --
185824
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3099 us
137104
  -- idle --
136704
  -- idle --
  -- task1 --
128368
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3223 us
81088
  -- idle --
80688
  -- idle --
  -- task1 --
71008
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3168 us
25168
  -- idle --
24768
  -- idle --
  -- task1 --
13744
  -- idle --
  -- task2 --
asyncio.sleep(0) = 3056 us
455360
  -- idle --
454960
  -- idle --
  -- task1 --
Does anyone have suggestions to improve the performance?
thanks!
Re: optimizing uasyncio performance
Posted: Tue Dec 04, 2018 8:31 pm
by kevinkk525
Do you have other coroutines running?
You could try using a uasyncio version with priority queues to ensure that the mic coro is called faster: https://github.com/peterhinch/micropyth ... er/fast_io
Posted: Wed Dec 05, 2018 6:11 am
by Mike Teachman
I don't think so ... When await asyncio.sleep(0) is called all other coroutines should either be blocked waiting on a Barrier, or sleeping. I expected the scheduler to quickly return control to the coroutine that called await asyncio.sleep(0). The delay of 6+ms is unexpected. That seems excessive when no other coroutines are waiting to run. (which makes me think I'm doing something wrong ...)
I tried replacing the mainline usyncio with the fast_io version, but I still see the same delay after calling asyncio.sleep(0).
Posted: Wed Dec 05, 2018 9:21 am
by kevinkk525
6ms does seem a bit long if nothing else is running. maybe @pythoncoder knows more about it.
Do you have any feature of loboris port running like ftp? They spawn a new thread making the main thread slower. Maybe this is the problem?
Posted: Wed Dec 05, 2018 5:19 pm
For a nominal zero delay it is quicker to issue asyncio.sleep_ms(0) and quicker still to issue yield. However whenever you issue one of these, every other coro will get scheduled before it returns. Note that the Barrier runs a (minimal) coro while a task is waiting on it.
These delays soon add up. That said, a quick run on a Pyboard shows values around 450μs so a lot is down to the nature of the ESP32.
Posted: Fri Dec 07, 2018 3:48 pm
by Mike Teachman
Thanks for this idea. I tried turning off Telnet, FTP, and MQTT. This gave about a 5% performance improvement. Not very significant, but I'll take it!
Posted: Fri Dec 07, 2018 4:18 pm
by Mike Teachman
Thanks for these insights! .. here are the test results:
asyncio.sleep(0) = 6.6 ms delay
asyncio.sleep_ms(0) = 7.0 ms delay
yield = 6.5 ms delay
Yield came out on top, and the _ms() version is slowest to return. Note: I am using the uasyncio release in micropython-lib.
Unfortunately, still not good enough for the microphone handling part of this project. Next steps:
1. "forensics" -- enable debug logging in uasyncio and uasyncio.core to understand what is creating this delay. Perhaps some simple tuning in core.py can bring significant improvements?
2. possibly create a new _thread dedicated to the I2S microphone handler. And, keep using uasyncio in the uPy main thread to manage all the other sensors, display, MQTT, buttons, etc (which are not time critical).
Posted: Fri Dec 07, 2018 4:53 pm
by kevinkk525
Option 2 is what I'd try. It sounds like the best option for this scenario.
Posted: Fri Dec 07, 2018 5:48 pm
by rpr
I'm a total newbie just learning. Is it possible somehow to dedicate one of the two cores for a given task.
Posted: Fri Dec 07, 2018 7:27 pm
by Mike Teachman
Today, it's not possible to dedicate a uPy operation to a specific ESP32 core.
The closest I've seen to this ambition is an experimental dual-core option on the LoBo port . As I understand it, with this option, the uPy VM runs on one core, and the rest of the ESP32 core rtos tasks (wifi, etc) run on the other core. In practice, I haven't seen much improvement in the dual-core mode compared to running everything on one core.
I read somewhere that there is an effort underway (by Loboris maybe?) to enable splitting uPy operation between the two cores. That would help with my application I think.
