16x2 LCD
iz2rpn
Re: 16x2 LCD
Post by iz2rpn » Fri Feb 21, 2020 6:58 pm
shaoziyang wrote:
Fri Feb 21, 2020 8:11 am
I have modify the LCD1602 drive, add autoaddress() function add print() function.
https://github.com/micropython-Chinese- ... 2C_LCD1602
from machine import I2C, Pin
from mp_i2c_lcd1602 import LCD1602
from time import sleep_ms
i2c = I2C(1, sda=Pin(9), scl=Pin(10))
LCD = LCD1602(i2c)
LCD.puts("I2C LCD1602")
LCD = LCD1602(i2c)
  File "mp_i2c_lcd1602.py", line 20, in __init__
  File "mp_i2c_lcd1602.py", line 61, in autoaddr
Exception: I2C address detect error!
Re: 16x2 LCD
Post by jimmo » Fri Feb 21, 2020 11:59 pm
What does i2c.scan() return?
If it doesn't return anything, then check wiring and pull-ups.
shaoziyang
Re: 16x2 LCD
Post by shaoziyang » Sat Feb 22, 2020 3:12 am
Please note, most I2C LCD1602 module use 5V, but ESP32/STM32 use 3.3V, and I2C will not work in this case.
Fortunately, I2C LCD1602 module may work under 3.3V, but contrast needs to be adjusted with a potentiometer. Or you need a level conversion board for I2C signal.
iz2rpn
Re: 16x2 LCD
Post by iz2rpn » Sat Feb 22, 2020 5:00 am
i2c.scan() return 39
iz2rpn
Re: 16x2 LCD
Post by iz2rpn » Sat Feb 22, 2020 5:02 am
the link is right because i2c.scan () sees the contrast I don't write
iz2rpn
Re: 16x2 LCD
Post by iz2rpn » Sun Feb 23, 2020 1:10 pm
It works thanksImage
Inviato dal mio CLT-L09 utilizzando Tapatalk
Roberto.cadena
Re: 16x2 LCD
Post by Roberto.cadena » Sun May 17, 2020 6:47 am
How do you solve the problem? Thanks
