ESP32 multiple partitions
Posted: Sat Jan 12, 2019 7:21 pm
by krono
I'm trying to mount another recovery partition in addition to the default one mounted on "/flash".
I'm doing this because I want to restore a configuration file (json), in case of corruption of the primary partition.
I can't mount the second volume because I can't see it using uos.listdir() and I can't move in using uos.chdir("/recovery").
I've an ESP32 with Micropython 1.9.4.
This is my partition table:
nvs,      data, nvs,     0x9000,  0x4000
otadata,  data, ota,     0xd000,  0x2000
phy_init, data, phy,     0xf000,  0x1000
factory,  app,  factory, 0x10000, 1144k
ota_0,    app,  ota_0,   0x130000,1144k
ota_1,    app,  ota_1,   0x250000,1144k
internalfs, data,spiffs, 0x36e000,76k
recovery, data,spiffs, 0x381000,4k
Follows the code of inisetup.py:
# Mount primary partition
uos.VfsFat.mkfs(flashbdev.bdev)
vfsFlash = uos.VfsFat(flashbdev.bdev)
uos.mount(vfsFlash, '/flash')
uos.chdir("/flash")
uos.mkdir("resources")
# Write config file into primary partition
with open("resources/config.json", 'w') as f:
            f.write("...")
# Mount recovery partition
bdevRecovery = FlashBdev(2048 * 1024 // FlashBdev.SEC_SIZE)
bdevRecovery.START_SEC = 3674112 // SEC_SIZE
vfsRecovery = uos.VfsFat(bdevRecovery)
uos.mount(vfsRecovery, '/recovery')
uos.mkdir("recovery")
# Write config file into recovery partition
            f.write("...")
So to recap my target is to reset primary partition in case of corruption and use the recovery one to restore the json configuration file.
I didn't understand well VfsFat:
- what's the point of the calculation 2048 * 1024 // FlashBdev.SEC_SIZE which is done at the object allocation?
- how's the starting address of the partition calculated? (3674112 // SEC_SIZE)
Thank you in advance.
