Is the olimex board supported with its poe ethernet?
I would rather like that board as an upgrade from a quick and dirty wifi enabled hack to a cabled solution and hey, it even sorts out the power input. Would like to have that capability while keeping the code nearly equal for a board with and without ethernet. The olimex board was the cheapest i found, might there be any cheaper solutions on the market?
Olimex esp32-poe ethernet support?
Re: Olimex esp32-poe ethernet support?
Hi !
I have this board from Olimex but it doesn't work for me
lan = network.LAN(mdc=machine.Pin(23), mdio=machine.Pin(18), power=machine.Pin(12), phy_addr=1)
lan.active(True)
OSError: ethernet enable failed
I have tried many options (phy_addr=0/1, power=None, ...) without success.
Anyone with this problem?
Thanx !
lan.active(True)
Thanx !
I want to put here a link to this issue and its solution in Github:
[url]https://github.com/micropython/micropython/issues/4502[/url]
