Can't start REPL after success flash
lyell06
Post by lyell06 » Sat Jan 19, 2019 2:45 am
Hi
After flash my board with the latest firmware, I can't connect to the board with putty.
but when I try to connect the board with Arduino uart monitor, it show below message after power on:
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
ets Jun 8 2016 00:22:57
then , if I press the reset button, it can start REPL as below:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4732
load:0x40078000,len:7496
load:0x40080400,len:5512
entry 0x4008114c
[0;32mI (399) cpu_start: Pro cpu up.[0m
[0;32mI (399) cpu_start: Single core mode[0m
[0;32mI (400) heap_init: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (403) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM[0m
[0;32mI (409) heap_init: At 3FFC0E00 len 0001F200 (124 KiB): DRAM[0m
[0;32mI (416) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM[0m
[0;32mI (422) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM[0m
[0;32mI (428) heap_init: At 400915E0 len 0000EA20 (58 KiB): IRAM[0m
[0;32mI (435) cpu_start: Pro cpu start user code[0m
[0;32mI (5) cpu_start: Starting scheduler on PRO CPU.[0m
OSError: [Errno 2] ENOENT
MicroPython v1.9.4-779-g5064df207 on 2019-01-13; ESP32 module with ESP32
is there any reason cause the board enter to boot 0x3 instead of 0x13?
by the way, the board works well with arduino IDE.
thanks
fdufnews
Re: Can't start REPL after success flash
Post by fdufnews » Sat Jan 19, 2019 1:12 pm
Obviously, the Arduino UART monitor puts the handshake lines in a state that makes the ESP32 boot in download mode.
Arduino UART monitor is not REPL friendly. Arduino UART monitor works in line mode. REPL expects a terminal working in character mode. You'd better use a terminal software like putty or realterm.
