i2s compatibility
Mike Teachman
Re: i2s compatibility
Post by Mike Teachman » Wed Feb 13, 2019 4:41 pm
Dogostyle wrote:
Fri Feb 08, 2019 4:58 pm
I have some questions though, why you decimate or prune your samples before saving into the SD?. And, how can I achieve full resolution (18bits) from the mic (https://cdn-shop.adafruit.com/product-f ... asheet.PDF)?
There is now a better way to save full resolution mic samples to external SD Card or the internal filesystem (credit to @MikeShi42 on github for this implementation). Please take a look at the new example#5 in the I2S usage guide. Compared to my previous post, this example uses 1/2 the DMA memory and does not require a prune() function.
The I2S guide also has a new example#4 describing how to use an I2S Microphone based on the INMP441 device (again, credit to @MikeShi42 on github for developing this example). The INMP441 I2S Mic is likely a better choice than the Adafruit I2S Mic which is based on the SPH0645LM4H device. Unfortunately, the SPH0645LM4H device was designed with non-standard I2S timing and appears to have some limitations when used with the ESP32 micro (and possibly other microcontrollers that support an I2S interface). I'll make a detailed post outlining these limitations in the near future.
Serjaru
Post by Serjaru » Mon Oct 21, 2019 8:44 pm
I can not understand if there is a fimrware.bim for esp32 with i2s support or not? everyone writes, even there are examples, but in reality I can’t find. I downloaded it from https://github.com/miketeachman/micropython and build, but "NameError: name 'os' isn't defined"
Where i can download ready firmware.bin with i2s????????
Post by jimmo » Mon Oct 21, 2019 11:25 pm
There isn't a pre-built firmware available for this. Hopefully it gets merged into master at quite soon and it'll just become part of the main firmware. You can follow the progress here: https://github.com/micropython/micropython/pull/4471
Anyway, when you built it yourself, where did the error come from? When you deployed the firmware or when you were building. Btw, you linked to the repo, but were you building the esp32-i2s branch? i.e. https://github.com/miketeachman/micropy ... /esp32-i2s
Mike Teachman
Post by Mike Teachman » Tue Oct 22, 2019 3:57 pm
Here is a binary to try out, in a Google Drive folder:
https://drive.google.com/open?id=1AlhGX ... nvgz57CibY
This firmware supports I2S using this commit PR https://github.com/miketeachman/micropy ... 10868dfa71 and includes the lastest Micropython commits as of Oct 22 2019.
I tested with one of the I2S examples using a Lolin D32 Pro module.
https://github.com/miketeachman/micropy ... -32bits.py
water
Post by water » Wed Nov 13, 2019 8:36 am
Hi, I want to convert analog audio (Line in) via I2S, likes http://www.ti.com/lit/ds/symlink/pcm1808.pdf, please give some suggest.
Thanks.
Mike Teachman
Post by Mike Teachman » Thu Nov 14, 2019 2:47 pm
You might want to check out the ADC Data Collection feature in the Loboris port of the ESP32.
https://github.com/loboris/MicroPython_ ... o/wiki/adc
This feature uses an I2S peripheral to read an ADC and collect samples in the background using DMA.
This capability is not yet implemented in the mainline of MicroPython
