Pulse counter support
Re: Pulse counter support
Post by OutoftheBOTS_ » Thu Aug 01, 2019 8:40 pm
pidou46 wrote:
Thu Aug 01, 2019 5:53 am
It seems able to handel encoders: https://docs.espressif.com/projects/esp ... /pcnt.html
- it count rising and/or falling edge
- a filter can be set to avoid glinches
- up to 8 counter are availables, not as much as STM32, but it enable quite sophisticated projects.
But now the hardest part is how to bring it to esp32 micropython port ?
My C skills dates from ages, and I have no idea where to start with ? I guess setting up a toolchain (GCC, ESP-IDF, ect...)
Is there somewhere a tutorial or even a sample of ported fonctionality ?
Thanks for the link to the info. The info isn't detailed but from what I read it won't read an quadrature encoder. It does have a 2 pin mode but from what I can gather it works by 1 pin is the counter pin and the other pin is a direction pin (something like a stepper motor driver). A quadrature encoder works differently were both pins are counter pins but depending on the order of the rising and falling of the 2 pins whether it is counting up or down.
The PCNT would be great to have added for reading single channel encoder but not sure if it will be capable of reading a quadrature encoder
see STM32F407 encoder mode that is capable of both single and quadrature encoders https://www.st.com/content/ccc/resource ... %2Cnull%5D
Post by OutoftheBOTS_ » Sat Aug 03, 2019 6:55 am
If you really want to use ESP and need to count a number of Quadrature encoders then you might be interested in this https://lsicsi.com/products/Development ... /LS7366RSh it has 6 32bit quadrature counters and is read by SPI. It is an ardunio shield made by the manufacturer of the LS7366R chip
elliotwoods
Post by elliotwoods » Wed Dec 04, 2019 8:14 am
Hah interesting
I was looking into this exact same thing today.
I implemented to C side of things:
https://github.com/elliotwoods/ESP32-Qu ... master/src
Now I'm looking into making it a MicroPython module for my own use
To note : you can use the ESP32's hardware counter.
It works perfectly.
If A rises high and B is low, count up
If A rises high and B is high, count down
Look at the states of A and B to get an 'addition factor' to multiply your resolution by 4 (check Encoder.cpp at link above)
