(nothing running on the esp, connecting with putty works fine every time):
rshell -p /dev/ttyS5 -a
Connecting to /dev/ttyS5 ...
b'\x1b[0;32mI (426) cpu_start: Pro cpu up.\x1b[0m\r\n\x1b[0;32mI (427) cpu_start: Application information:\x1b[0m\r\n\x1b[0;32mI (427) cpu_start: Compile time: 00:43:59\x1b[0m\r\n\x1b[0;32mI (429) cpu_start: Compile date: Mar 25 2019\x1b[0m\r\n\x1b[0;32mI (434) cpu_start: ESP-IDF: v3.3-beta1-268-g5c88c5996\x1b[0m\r\n\x1b[0;32mI (441) cpu_start: Single core mode\x1b[0m\r\n\x1b[0;32mI (445) heap_init: Initializing. RAM available for dynamic allocation:\x1b[0m\r\n\x1b[0;32mI (452) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM\x1b[0m\r\n\x1b[0;32mI (458) heap_init: At 3FFB92B0 len 00026D50 (155 KiB): DRAM\x1b[0m\r\n\x1b[0;32mI (464) heap_init: At 3FFE0440 len 0001FBC0 (126 KiB): D/IRAM\x1b[0m\r\n\x1b[0;32mI (471) heap_init: At 40078000 len 00008000 (32 KiB): IRAM\x1b[0m\r\n\x1b[0;32mI (477) heap_init: At 400928AC len 0000D754 (53 KiB): IRAM\x1b[0m\r\n\x1b[0;32mI (483) cpu_start: Pro cpu start user code\x1b[0m\r\n\x1b[0;32mI (54) cpu_start: Starting scheduler on PRO CPU.\x1b[0m\r\nOSError: [Errno 2] ENOENT\r\nMicroPython v1.10-230-ge0c6dfe90 on 2019-03-25; ESP32 module with ESP32\r\nType "help()" for more information.\r\n>>> '
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1197, in connect
ip_address = socket.gethostbyname(port)
socket.gaierror: [Errno -5] No address associated with hostname
During handling of the above exception, another exception occurred:
File "/home/kevin/.local/bin/rshell", line 11, in <module>
sys.exit(main())
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/command_line.py", line 4, in main
rshell.main.main()
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 2730, in main
real_main()
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 2692, in real_main
connect(args.port, baud=args.baud, wait=args.wait, user=args.user, password=args.password)
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1203, in connect
connect_serial(port, baud=baud, wait=wait)
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1227, in connect_serial
dev = DeviceSerial(port, baud, wait)
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1473, in __init__
Device.__init__(self, pyb)
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1280, in __init__
elif not self.remote_eval(test_unhexlify):
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1390, in remote_eval
return eval(self.remote(func, *args, **kwargs))
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/main.py", line 1368, in remote
self.pyb.enter_raw_repl()
File "/home/kevin/.local/lib/python3.6/site-packages/rshell/pyboard.py", line 187, in enter_raw_repl
raise PyboardError('could not enter raw repl')
rshell.pyboard.PyboardError: could not enter raw repl
I have no problems connecting to my esp8266s.
Also connecting directly after flashing a firmware to the esp32 works fine.
For flashing I have to reset the esp multiple times too until it connects properly.
