Stuck on beginning the install
I have an esp32 with 4MB spiram, SD-Card etcetera.
Since the LoBo seems to have too many issues because it's not maintained for a long time, I would like to switch to this micropython.
But somehow I totally don't understand the first part for installation:
The ESP-IDF changes quickly and MicroPython only supports a certain version. The git hash of this version can be found by running make without a configured ESPIDF. Then you can fetch only the given esp-idf using the following command:
$ git clone https://github.com/espressif/esp-idf.git
$ git checkout <Current supported ESP-IDF commit hash>
$ git submodule update --init --recursive
So I run the git clone and then I need to "run make without a configured ESPIDF". That should then give me a hint about the hash that is needed for the git checkout.
But there do I have to go to run the "make"? Because inside the newly created esp-idf the "make" makes no sense.
I feel silly but I think I miss something?
Re: Stuck on beginning the install
You have to run make in the micropython/ports/esp32 directory. The proper hash value for the esp-idf is inside Makefile. Yo you can as well open Makefile with an editor or the less command and take it from there.
Thanks, after some "fiddling around" I got to that point.
It now starts compiling but fails at
GEN build/esp32.common.ld
File "/home/me/esp-idf/tools/ldgen/ldgen.py", line 22, in <module>
from fragments import FragmentFileModel
File "/home/me/esp-idf/tools/ldgen/fragments.py", line 20, in <module>
from sdkconfig import SDKConfig
File "/home/me/esp-idf/tools/ldgen/sdkconfig.py", line 18, in <module>
from pyparsing import Word, printables, Combine, Literal, hexnums, quotedString, Optional, nums, removeQuotes, oneOf, Group, infixNotation, opAssoc
ImportError: No module named 'pyparsing'
Makefile:788: recipe for target 'build/esp32.common.ld' failed
make: *** [build/esp32.common.ld] Error 1
Which leads me to an open issue:
https://github.com/micropython/micropython/issues/4655
I also had this problem last week, caused I think because I have python 3 and python 2 installed nand default was python3
I edited the makefile and changed $(Q)$(PYTHON) to $(Q)$(PYTHON2)
This is probably not the best solution, but it was a quick fix for me.
By following the suggestions in the issue I got around that.devnull wrote: ↑Sat Apr 06, 2019 12:21 pmI also had this problem last week, caused I think because I have python 3 and python 2 installed nand default was python3
Now I run into the next issue, something with the frozen part:
# cat makefile
ESPIDF = $(HOME)/esp-idf
PORT = /dev/ttyS14
FLASH_MODE = qio
FLASH_SIZE = 4MB
CROSS_COMPILE = xtensa-esp32-elf-
SDKCONFIG = boards/sdkconfig.spiram
include Makefile
# make V=1 PYTHON=python2
GEN build/frozen_mpy.c
python2 ../../tools/mpy-tool.py -f -q build/genhdr/qstrdefs.preprocessed.h build/frozen_mpy/_boot.mpy build/frozen_mpy/apa106.mpy build/frozen_mpy/dht.mpy build/frozen_mpy/ds18x20.mpy build/frozen_mpy/flashbdev.mpy build/frozen_mpy/inisetup.mpy build/frozen_mpy/neopixel.mpy build/frozen_mpy/ntptime.mpy build/frozen_mpy/onewire.mpy build/frozen_mpy/upip.mpy build/frozen_mpy/upip_utarfile.mpy build/frozen_mpy/webrepl.mpy build/frozen_mpy/webrepl_setup.mpy build/frozen_mpy/websocket_helper.mpy > build/frozen_mpy.c
File "../../tools/mpy-tool.py", line 865, in <module>
main()
File "../../tools/mpy-tool.py", line 853, in main
raw_codes = [read_mpy(file) for file in args.files]
File "../../tools/mpy-tool.py", line 721, in read_mpy
return read_raw_code(f, qstr_win)
File "../../tools/mpy-tool.py", line 703, in read_raw_code
return RawCodeBytecode(fun_data.buf, qstrs, objs, raw_codes)
File "../../tools/mpy-tool.py", line 426, in __init__
super().__init__(MP_CODE_BYTECODE, bytecode, 0, qstrs, objs, raw_codes)
TypeError: super() takes at least 1 argument (0 given)
../../py/mkrules.mk:122: recipe for target 'build/frozen_mpy.c' failed
make: *** [build/frozen_mpy.c] Error 1
make: *** Deleting file 'build/frozen_mpy.c'
https://github.com/micropython/micropython/issues/4674
I don't think this is is a bug/issue, sounds like configuration / setup issue to me.
Yes that's what I thought too.
So I removed my entire ~/micropython and started new (so having a clean and latest version again) while strictly following all steps for micropython in general and for the esp32 port.
Same result.
git clone https://github.com/micropython/micropython.git
cd micropython
make -C mpy-cross
git submodule init lib/berkeley-db-1.xx
cd ports/esp32
vi makefile
PORT = /dev/ttyS14
FLASH_MODE = qio
FLASH_SIZE = 4MB
include Makefile
MPY modules/_boot.py
mkdir -p build/frozen_mpy/
../../mpy-cross/mpy-cross -o build/frozen_mpy/_boot.mpy -s _boot.py modules/_boot.py
MPY modules/apa106.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/apa106.mpy -s apa106.py modules/apa106.py
MPY modules/dht.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/dht.mpy -s dht.py modules/dht.py
MPY modules/ds18x20.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/ds18x20.mpy -s ds18x20.py modules/ds18x20.py
MPY modules/flashbdev.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/flashbdev.mpy -s flashbdev.py modules/flashbdev.py
MPY modules/inisetup.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/inisetup.mpy -s inisetup.py modules/inisetup.py
MPY modules/neopixel.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/neopixel.mpy -s neopixel.py modules/neopixel.py
MPY modules/ntptime.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/ntptime.mpy -s ntptime.py modules/ntptime.py
MPY modules/onewire.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/onewire.mpy -s onewire.py modules/onewire.py
MPY modules/upip.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/upip.mpy -s upip.py modules/upip.py
MPY modules/upip_utarfile.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/upip_utarfile.mpy -s upip_utarfile.py modules/upip_utarfile.py
MPY modules/webrepl.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/webrepl.mpy -s webrepl.py modules/webrepl.py
MPY modules/webrepl_setup.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/webrepl_setup.mpy -s webrepl_setup.py modules/webrepl_setup.py
MPY modules/websocket_helper.py
../../mpy-cross/mpy-cross -o build/frozen_mpy/websocket_helper.mpy -s websocket_helper.py modules/websocket_helper.py
main()
There are quite a few people like me who have not problem in building the binaries using the provided repositories. Please check if you followed the instructions in the README of esp-idf an micropython literally.
From the log of the build here I see, that mpy_tool is called with python3. I agree that there might be a mismatch between all the required python versions, but maybe you could change your system set-up to use python2 as default for python. I've read that it works different for @devnull.
Or may you changed the setting in py/mkenv.mk too, where PYTHON is set to python3 .
Sorry but in my logs I see:Roberthh wrote: ↑Sat Apr 06, 2019 2:38 pmThere are quite a few people like me who have not problem in building the binaries using the provided repositories. Please check if you followed the instructions in the README of esp-idf an micropython literally.
Yes, but the python version to be used is set by your make call option, it is not hard coded in the script. Anyhow, meanwhile, Damien pushed a change to mpytools.py to work with python2. So the issue should be settled.
