Page 2 of 3
Re: Waveshare e-paper display how to rotate?
Posted: Fri Apr 26, 2019 2:08 pm
by JumpZero
@pythoncoder:
I’d like to have bigger fonts so I’ve check your
micropython-font-to-py repo as you suggested here above.
But so far I had no success.
I understand as per your documentation that when using the writer as in:
the device must inherit from framebuf
But in my code I don’t have such a device. I have tried to pass the framebuffer as a device
wri = Writer(fb_portrait_black, freesans20)
but receive this error:
AttributeError: 'FrameBuffer' object has no attribute 'width'
Seems normal: yes the FrameBuffer' object has no attribute 'width'
I tried to pass the EPD object:
But got this error:
ValueError: Device must be derived from FrameBuffer.
So I’m a bit lost do I have to create an object from EPD and FrameBuffer? How can I do this?
Thanks in advance if you can help.
PS: my code is the same as posted here above + from writer import Writer + import freesans20, of course
Posted: Fri Apr 26, 2019 5:43 pm
I must admit I hadn't considered the case where someone might want to write to a
framebuf and then output the result to a separate display instance. I think you'll have to create a dummy display device derived from
framebuf and point the Writer at that.
I think the dummy could be along these lines. Note I haven't actually tried this:
class DummyDisplay(framebuf.FrameBuffer):
def __init__(self, width, height, mode):
self.height = height # your height and width in pixels
self.width = width
self.buffer = bytearray(height * width)
super().__init__(self.buffer, width, height, mode)
Posted: Sun Apr 28, 2019 1:14 pm
by JumpZero
Hi
@pythoncoder thank you very much for your support. It works!
It took me sometime because I’m not comfortable enough with python class definition (
self and
super() are still a bit obscure, but I learn!). I had to change some minor things in this DummyDisplay class and this took me time and tries but now I can use bigger fonts.
Here is my code:
import framebuf
import epaper2in13b
import freesans20
sck = Pin(13); mosi = Pin(14); cs = Pin(15); busy = Pin(25); rst = Pin(26); dc = Pin(27); miso = Pin(12)
spi = SPI(baudrate=100000, polarity=0, phase=0, sck=sck, mosi=mosi, miso=miso)
e = epaper2in13b.EPD(spi, cs, dc, rst, busy)
e.init()
def __init__(self, buffer, width, height, format):
self.width = width
self.buffer = buffer
self.format = format
super().__init__(buffer, width, height, format)
w=104; h=212
buf_black = bytearray(w * h // 8)
buf_red = bytearray(w * h // 8)
black_red = 0 # will be black on buf_black, red on buf_red
white = 1
d_b = DummyDisplay(buf_black, w, h, framebuf.MONO_HLSB)
d_r = DummyDisplay(buf_red, w, h, framebuf.MONO_HLSB)
d_b.fill(white)
d_r.fill(white)
wri_b = Writer(d_b, freesans20, False)
Writer.set_textpos(d_b, 0, 0) # verbose = False to suppress console output
wri_b.printstring('Sunday\n', True)
wri_b.printstring('28/04/2019\n',True)
wri_b.printstring('14:30', True)
wri_r = Writer(d_r, freesans20, False)
Writer.set_textpos(d_r, 100, 0)
wri_r.printstring('uPython\n', True)
wri_r.printstring(' :-)', True)
print('Sending to display')
e.display_frame(buf_black, buf_red)
print('Done!.......')
e.sleep() # recommended by manufacturer to avoid damage to display
print('E-paper sleeping!...')
print('END')
Next step will be to use your font-to-py to generate some fonts!
Here is a photo of the result
Thanks again I really appreciate
Jmp0
Posted: Mon Apr 29, 2019 6:20 am
Congratulations on getting it working.
I strongly recommend getting proficient with Python's object oriented capabilities, either from a book or by following an online course on a PC.
Posted: Tue Oct 26, 2021 5:39 am
by JordanDarabos
Hello there,
So I've been trying for a couple days to rotate this Waveshare 2.9" E-Paper Module(B/W) and have had no success. I can display text and shapes in portrait mode with no issues. I even made a custom font library using @pythoncoder examples. However, I'm having the hardest time rotating this for some reason. Any help is greatly appreciated. I've stripped down my code to just include what's necessary to run the screen and rotate it. I tried the method JumpZero is using and have had no luck, it just displays a bunch of junk on the screen. Below is my code as it stands now.
import epaper2in9, time
from machine import SPI, Pin
import myfont
import framebuf
spi = SPI(2, baudrate=2000000, polarity=0, phase=0)
cs = Pin(5)
dc = Pin(17)
rst = Pin(16)
busy = Pin(4)
e = epaper2in9.EPD(spi, cs, dc, rst, busy)
e.init()
w = 296
h = 128
x = 0
y = 0
e.clear_frame_memory(b'\xFF')
e.display_frame()
buf = bytearray(w * h // 8)
fb = framebuf.FrameBuffer(buf_black, w, h, framebuf.MONO_VLSB)
fb.fill(1)
fb.text('Hello world!', 0, 0,0)
x=0; y=-1; n=0; m=0
for i in range(0, 16):
for j in range(0, 296):
m = (n-x)+(n-y)*15
buf[m] = buf_black[n]
n +=1
x = n+i+1
y = n-1
e.set_frame_memory(buf, x, y, w, h)
e.display_frame()
Posted: Tue Oct 26, 2021 10:45 am
Why not try the approach of @JumpZero which has been proven to work? It has the advantage of not requiring explicit rotation. You create a dummy display with a portrait format (w < h) and render text to it. Then simply copy the buffer to the landscape format display.
Posted: Tue Oct 26, 2021 8:49 pm
by JordanDarabos
pythoncoder wrote: ↑Tue Oct 26, 2021 10:45 am
Hey Pythoncoder,
Thank you for your quick response! If I'm understanding you correctly I have tried to do this and have had no luck getting it to work. You mean swapping the H and W before sending it to the display correct? In the library of this particular screen (2.9") it seems update differently than JumpZeros so that might be causing an issue there. I was able to get something horizontal on the display this with the below code but I'm not quite sure what could be causing the issue. Any direction would be appreciated. Cheers!
import myfont
import framebuf
cs = Pin(5)
dc = Pin(17)
rst = Pin(16)
busy = Pin(4)
e.init()
self.width = width
def show():
w = 128
h = 296
start_x = 0
start_y = 0
# # write hello world with black bg and white text
# from onelink_logo import onelink_logo
# e.clear_frame_memory(b'\xFF')
# e.set_frame_memory(onelink_logo, x, y, w, h)
# e.display_frame()
d_b = DummyDisplay(buf_black, w, h, framebuf.MONO_VLSB)
d_b.fill(1)
wri = Writer(d_b, myfont)
wri.printstring('Hello World')
n=0
m = ((j+1) * 16) - (i+1)
#print(n," -> ",m)
n +=1
# x=0; y=-1; n=0; m=0
# for i in range(0, 16):
# for j in range(0, 296):
# m = (n-x)+(n-y)*15
# #print(n," -> ",m)
# buf[m] = buf_black[n]
# n +=1
# x = n+i+1
# y = n-1
# clear
e.set_frame_memory(buf, start_x, start_y, w, h)
e.display_frame()
Posted: Wed Oct 27, 2021 9:07 am
You should be able to copy with something like:
for n, x in enumerate(buf_black):
buf[n] = x
However it should be possible to just use one buffer, pointing the display driver at
buf_black directly, as @JumpZero did. Note that his code has added complexity because his display is a red/black display which is effectively two displays. But he does no buffer copying, simply pointing the display driver at his red and black buffers.
Posted: Wed Jul 13, 2022 5:03 pm
by GalUnDrux
Hey,
Sorry to revive an old thread, I am having similar issues...
I am trying to interface a 1.54" V2 Waveshare e-paper display with a Waveshare RP2040-Zero but I cannot find a compatible driver or any example code to reverse-engineer!
@devnull I too need a rotated display due to hardware layout and constraints..
Did you manage to get this working on the 1.54", do you have a V1 or V2 screen?
If you still have it, any chance you could share your setup code please?
JumpZero wrote: ↑Thu Apr 25, 2019 12:48 pm
Hi!
@devnull:
You can try this code, it's adapted from my 104x212 to your 200x200, maybe I've done some typo. I cannot test it since I don't have a 200x200 e-paper display. If yours is black only remove all lines with reference to red. It may give you a path to follow even if doesn't work out of the box
The algorithm is the one I use, I've just changed some figures.
You have to add all your init and spi stuff..
h = 200; w = 200 # e-paper heigth and width.
buf_black = bytearray(w * h // 8) # used by frame buffer (landscape)
buf_red = bytearray(w * h // 8) # used by frame buffer (landscape)
buf_epaper_black = bytearray(w * h // 8) # used to display on e-paper after bytes have been
buf_epaper_red = bytearray(w * h // 8) # moved from frame buffer to match e-paper (portrait)
import framebuf
fb_black = framebuf.FrameBuffer(buf_black, w, h, framebuf.MONO_VLSB)
fb_red = framebuf.FrameBuffer(buf_red, w, h, framebuf.MONO_VLSB)
white = 1
#clear red & black screens, write in black on top left and in red bootom right
fb_black.fill(white)
fb_red.fill(white)
fb_black.text('Hello world!', 0, 0,black_red)
fb_red.text('Hello world!', 110, 90,black_red)
# Move frame buffer bytes to e-paper buffer to match e-paper bytes oranisation.
# That is landscape mode to portrait mode. (for red and black buffers)
for i in range(0, 25):
for j in range(0, 200):
m = (n-x)+(n-y)*24
buf_epaper_black[m] = buf_black[n]
buf_epaper_red[m] = buf_red[n]
n +=1
x = n+i+1
y = n-1
e.display_frame(buf_epaper_black, buf_epaper_red)
Thank you!
Posted: Sat Jul 16, 2022 8:20 pm
by McRaceface
GalUnDrux wrote: ↑Wed Jul 13, 2022 5:03 pm
Would this help?
https://github.com/waveshare/e-Paper/bl ... V2_test.py
