[SOLVED] imports issue
LukeVideo
Post by LukeVideo » Wed May 22, 2019 7:51 am
Hello again,
I'm trying to import a module to connect to my wifi. i'm using a module because i don't want the ssid or password to be tracked on github :mrgreen:
But it don't work in my main.py. In repl it works fine, I import ConnectWifi in both main.py and in the repl prompt and :
connect to wifi
File "main.py", line 15, in <module>
NameError: name 'ConnectWiFi' isn't defined
MicroPython v1.10-331-ge38c68310-dirty on 2019-05-09; ESP32 module with ESP32
>>> import ConnectWifi
>>> ConnectWifi.greetings()
Hellooooo !
You'll notice the first line is a print statement from these few lines of code :
import ConnectWifi
  ConnectWifi
except NameError:
  print("no ConnectWifi")
  print("connect to wifi")
  ConnectWiFi.greetings()
I'm trying to check if the import failed or not, it seems to pass but then i can't call it. ConnectWifi.greetings fails and the whole file fails.
Am i doing something wrong?
LukeVideo
Re: imports issue
Post by LukeVideo » Wed May 22, 2019 8:54 am
Oh... I was trying to import the file and not the functions within. So it works in repl but in a .py file you should import a class or a function not the file directly...
:oops:
Re: imports issue
Post by jimmo » Wed May 22, 2019 9:06 am
You should be able to do exactly what you did in the REPL from main.py
It's just like regular Python. If you have foo.py containing "def bar".
import foo
foo.bar()
or
from foo import bar
bar()
LukeVideo
Re: imports issue
Post by LukeVideo » Wed May 22, 2019 9:16 am
well, i'm not sure why it didn't work. I'm not a python expert so i thought it might be because there a just functions in the file and no class ? So i should import the function from the file ?
Anyway this works fine
from ConnectWifi import connect
connect()
Is the usual import refere to a class named like the file so that python knows what to do ? In my case in the ConnectWifi there is no ConnectWifi class...
Re: imports issue
Post by jimmo » Wed May 22, 2019 9:23 am
As far as imports go, there's no distinction between classes, functions or just plain old variables.
It just so happens that in the "import foo" case, the "foo" you get looks a bit like a class because you use the "." notation to access its contents.
i e. if this was foo.py
def bar():
  print('bar')
class Thing:
  def baz():
    print('baz')
x = 22
then
import foo
foo.bar()
t = foo.Thing()
t.baz()
print(foo.x)
LukeVideo
Re: imports issue
Post by LukeVideo » Thu May 23, 2019 8:16 am
Thanks jimmo for the example.
i still don't really understand why my
import foo
foo.bar()
returned foo isn't defined ???
Anyway it's all good now.
Thanks.
