however, the text autoscrolls to the next line when it goes off screen.from m5stack import *
from m5ui import *
clear_bg(0x222222)
btnA = M5Button(name="ButtonA", text="ButtonA", visibility=False)
btnB = M5Button(name="ButtonB", text="ButtonB", visibility=False)
btnC = M5Button(name="ButtonC", text="ButtonC", visibility=False)
label1 = M5TextBox(299, 120, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
from numbers import Number
position = None
label1.setText('Hello everyone who uses an M5Stack or M5Stick.')
label1.setPosition(300, 121)
position = 300
label1.setPosition(x=position)
position = (position if isinstance(position, Number) else 0) + -1
if position == 0:
position = 300
wait(0.001)
https://www.youtube.com/embed/YJlw2PE75IU
What I would like is for the "offscreen" text to be hidden instead of appearing on the next line.
Q1, is this possible?
Q2, if yes, how?
Q3, Please can you tell me what documents I need to be reading and research to understand this please?
