Need help making module
Posted: Sun Jun 09, 2019 8:56 pm
by Lennyz1988
I am trying to add functions to an existing module. I am not an experienced coder so please be gentle. I am trying to learn.
The module is about the ESP32-CAM support. I want to add a flip function. The module is already working. I just want to add functions to it. I manage to call the function that I added using:
import camera
camera.flip()
But it always returns "Flipping Failed". What am I doing wrong? I tried to look at the Arduino CameraWebServer example because all the other functions used in the camera module look similair to the Arduino example.
The files used:
https://github.com/Lennyz1988/micropyth ... odcamera.c
https://github.com/Lennyz1988/esp32-cam ... e/sensor.h
https://github.com/Lennyz1988/esp32-cam ... p_camera.h
Arduino example:
 sensor_t * s = esp_camera_sensor_get();
  //initial sensors are flipped vertically and colors are a bit saturated
  if (s->id.PID == OV3660_PID) {
    s->set_vflip(s, 1);//flip it back
    s->set_brightness(s, 1);//up the blightness just a bit
    s->set_saturation(s, -2);//lower the saturation
  //drop down frame size for higher initial frame rate
  s->set_framesize(s, FRAMESIZE_QVGA);
In the file sensors.h is the function I want to add.
sensors.h
typedef struct _sensor sensor_t;
typedef struct _sensor {
    sensor_id_t id;             // Sensor ID.
    uint8_t  slv_addr;          // Sensor I2C slave address.
    pixformat_t pixformat;
    camera_status_t status;
    int xclk_freq_hz;
    // Sensor function pointers
    int  (*init_status)         (sensor_t *sensor);
    int  (*reset)               (sensor_t *sensor);
    int  (*set_pixformat)       (sensor_t *sensor, pixformat_t pixformat);
    int  (*set_framesize)       (sensor_t *sensor, framesize_t framesize);
    int  (*set_contrast)        (sensor_t *sensor, int level);
    int  (*set_brightness)      (sensor_t *sensor, int level);
    int  (*set_saturation)      (sensor_t *sensor, int level);
    int  (*set_gainceiling)     (sensor_t *sensor, gainceiling_t gainceiling);
    int  (*set_quality)         (sensor_t *sensor, int quality);
    int  (*set_colorbar)        (sensor_t *sensor, int enable);
    int  (*set_whitebal)        (sensor_t *sensor, int enable);
    int  (*set_gain_ctrl)       (sensor_t *sensor, int enable);
    int  (*set_exposure_ctrl)   (sensor_t *sensor, int enable);
    int  (*set_hmirror)         (sensor_t *sensor, int enable);
    int  (*set_vflip)           (sensor_t *sensor, int enable);
    int  (*set_aec2)            (sensor_t *sensor, int enable);
    int  (*set_awb_gain)        (sensor_t *sensor, int enable);
    int  (*set_agc_gain)        (sensor_t *sensor, int gain);
    int  (*set_aec_value)       (sensor_t *sensor, int gain);
    int  (*set_special_effect)  (sensor_t *sensor, int effect);
    int  (*set_wb_mode)         (sensor_t *sensor, int mode);
    int  (*set_ae_level)        (sensor_t *sensor, int level);
    int  (*set_dcw)             (sensor_t *sensor, int enable);
    int  (*set_bpc)             (sensor_t *sensor, int enable);
    int  (*set_wpc)             (sensor_t *sensor, int enable);
    int  (*set_raw_gma)         (sensor_t *sensor, int enable);
    int  (*set_lenc)            (sensor_t *sensor, int enable);
} sensor_t;
In the file esp_camera.h is the pointer:
 * @brief Get a pointer to the image sensor control structure
 * @return pointer to the sensor
sensor_t * esp_camera_sensor_get();
In the file modcamera.c (this is the module) I added the following parts:
STATIC mp_obj_t camera_flip(){
    if (!s) {
        ESP_LOGE(TAG, "Flipping Failed");
        return mp_const_false;
    s->set_vflip(s, 1);
    return mp_const_none;
STATIC MP_DEFINE_CONST_FUN_OBJ_0(camera_flip_obj, camera_flip);
STATIC const mp_rom_map_elem_t camera_module_globals_table[] = {
    { MP_ROM_QSTR(MP_QSTR___name__), MP_ROM_QSTR(MP_QSTR_camera) },
    { MP_ROM_QSTR(MP_QSTR_flip), MP_ROM_PTR(&camera_flip_obj) },
Re: Need help making module
Posted: Mon Jun 10, 2019 7:42 am
by stijn
Looks like esp_camera_sensor_get is returning NULL. Which, looking at https://github.com/espressif/esp32-came ... p_camera.h, is because you're not initalizing the camera using esp_camera_init.
Just for information: you're using incorrect terminology here which can be confusing. It alwyas returns False, it logs "Flipping Failed".
Posted: Mon Jun 10, 2019 8:01 am
by Lennyz1988
Aah you are right! Thank you! I'ts working as it should.
And thank you for the tip about using the correct terminology. I will try to use correct terminology.
