How do I build with bluetooth classic + bluedroid support?
aroldorosenberg
Post by aroldorosenberg » Mon Jun 24, 2019 4:26 pm
I'm trying to do something similar to what I've done with the NodeMCU lua interpreter, namely to accept input from the bluetooth interface running with the spp profile.
This was pretty simple for the lua interpreter, just a matter of running make menuconfig and enabling the relevant options and I managed to get it done within 1-2 nights, but I haven't managed to get anything done on the micropython firmware 1) because there's no menuconfig build target 2) I can't figure out how to solve all the linker errors that come up when I try to add the relevant lines to the makefile. No luck either with the loboris fork with psRAM for similar reasons (the menuconfig is there, but the option to enable bluetooth controller is not). It's almost as if it's not meant to be modified like NodeMCU is, even though they run on the same hardware, and are built against the same esp-idf.
Is there a simple way to do this that I'm overlooking?
