PIR Sensor + LED || Is this code well implemented?
klindber
Post by klindber » Sat Jun 29, 2019 4:49 pm
Hello!
I made this testing of a PIR Sensor (movement) that just turns a LED on, using ISR's.
I just want to share it with you and ask if this interrupt is well implemented, and else how can it be improved.
from time import sleep
motion = False
def handle_interrupt(pin):  #Avoid using print() inside isr
  global motion
  motion = True
  global int_pin
  int_pin = pin
led = Pin(4, Pin.OUT)
pir = Pin(14, Pin.IN)
pir.irq(trigger = Pin.IRQ_RISING, handler = handle_interrupt)
  if motion:
    print('Motion detected! Interrupt on pin:', int_pin)
    led.on()
    sleep(5)
    led.off()
    print('Motion stopped')
    motion = False
Thanks for any help!
-klindber
Re: PIR Sensor + LED || Is this code well implemented?
Post by dhylands » Sat Jun 29, 2019 9:30 pm
You may want to use micropython.schedule, then you don't need to poll in your main code.
See: https://docs.micropython.org/en/latest/ ... n-schedule (and the rest of the page is all about writing ISRs)
Post by pythoncoder » Sun Jun 30, 2019 7:25 am
If your aim is to understand interrupts then your approach is fine (although I agree with the comment of @dhylands).
But in terms of the actual application the interrupt isn't adding any functionality that wouldn't be available by polling the pin. Something along these lines is simpler and should work equally well.
  if pir():
    print('Motion detected!')
    led.on()
    sleep(5)
    led.off()
    if not pir():
Learning exercises aside, it's best to use interrupts only when there is a real need for them.
